30k front wheel bearing check/pack. Didn't expect this carnage!
Hot spots on the inner sleeve portion.
This outer bearing was new 30k ago. Replaced with new bearing and race from the parts store. Will see how it holds up. The spindle also showed some hot spots on it. TBD on addressing that.
Quiz: the axle nuts on one side were barely hand tight. The axle nuts on the other side were tight enough that I had to use the 54mm wrench on a 3/8 rachet to remove. Guess which side this damaged outer bearing was on...
Could be coincidental?
Answer: the loose side. This supports my biased theory that I'd rather over-tighten wheel bearings that leave too loose.
