What do I do?? Body is shot.
Fresno, CA
I've had a 1968 FJ40 for about 15 years. When I first got it I did a complete restoration of the frame including having it powder coated and engine swap with a 305 chevy engine. It's got 4-wheel disc brakes, suspension upgrade, shackle reverse, etc.
However...the body is trash.
At a minimum it needs both rocker panels, both rear fenders, both doors, the rear swing gates, floor, and on and on...
Any recommendations? Is a completely new tub my best route? Where's the best place to get one? Is there another out of the box option like rock crawler cage, etc.??
Just need some help getting started on a good path.
We need pictures. Tub options are Aquala (aluminum), Gozzard (fiberglass), and I think there is someone selling a steel tub for a lot of money. And you can get those in full or 3/4 or half tub. There are panels available for almost every part of the rig.
1970933
1970934
1970936
1970937
1970938
Where do you live? If it’s a rust belt then Aqualu or something of that nature if it’s dry and hot fixing would be an option. Need more pics to really say. Sill, floors etc
Nice Rig !! Its all relative on how much $$$ you want to spend. Aluminum tub,,,spendy. You ran right down the list of what needs to be replaced. Find the replacements and find a "good" sheet metal guy (with FJ40 experience if you are lucky) and have everything stitched on. Emphasis again on "good" not Joe next door with a 110V welder, and he's ready to tackle a challenging project. You are still going to spend, but it will not be as much as a new tub.
Kevo
I haven't stripped everything out of it in a while but I do recall there were a couple of bad spots in the floor. I might get it emptied out (spare parts, etc.) this weekend and assess the floor more thoroughly.
Kevo
I really don't want to spend a fortune but it seems like by the time I add up all the patch panels and body shop cost I'm almost to a new tub!
California...central valley. Hot and mostly dry.
If you do the work yourself you’ll save big time. Patch panels are readily available and vary in quality. Aqualu is expensive but permanent. Although not OEM. Depending on your goals for the truck...
Buy a welder and have some fun.
Mine looked worse than that after I had it sandblasted.
I'm no welder so the DIY option is not available to me. Looking at Aqualu's stuff and it's really nice. It sure would be nice to have a plug and play kit like that.
I hadn't welded in nearly 20 years. It's not hard.
If you can't weld it yourself, paying a body shop to do it really drives up the cost.
You should go ahead and sell it to me for dirt cheap!
You might try the Wanted section of the classifieds here on MUD. I got lucky and found a very decent used tub for my '71 FJ40 in Northern California earlier this year. Just one section of floor in the rear cargo area to patch with a good section from my old, rusty tub. I do have a decent MIG welder and Argon/CO2 tank. I might just have to sign up for the MIG/TIG class at the local UNM branch this fall. I haven't welded much since the last welding class almost 20 years ago, but I'm encouraged by the great job others here on MUD have done with their body repairs.
