decreased the neighborhood property values by building a canvas carport. new house, and the first time the cruiser has ever been uncovered. no more!
I failed to fix my electric seats. Got the new plastic gears and end caps, pulled the seat, tore it apart, fitted new bits, sewed it all back together, tested it. It moved forward about an inch then stopped. Moves back OK. I must of missed something. Will try again next week and this time I will pay more attention to the instructions...[emoji15]
Almost makes me wanna repaint my rigRebadged. All new OEM replacementsA heat gun, plastic razor blades, fishing line, and Goo Gone gel will be your friends for this task.
Yeah, a bit of Super Glue will help with that... I had the same issue.I had a problem a couple of weeks ago with a seat that only moved back, but not forward. It turned out on go the end caps fell out.
Make sure everything is in it's place.
I was particularly careful to make sure both tracks were aligned. I counted the threads on the rods and both sides were identical. I'm wondering if I have over tightened the plastic end cap.You didn't get the tracks installed evenly, probably.
Took the family up Mormon Immigrant Trail for some snow fun. Had a great time!
How will those book stay put?Started adding shelving for the passengers side window for quick easy access.
Shelving 50% completed used for daytime quick access. Items can also be accessed from the rear hatch if needed.
Pull strap with D ring stored in the middle
Water proof Frogg Toggs
Library for books and Magazine
Existing frequent needed item basket goes on the bottom
Will be adding one more shelf on top
Working gloves with room for rags and waterless hand cleaner![]()
Source and cost of all the new badging?Rebadged. All new OEM replacementsA heat gun, plastic razor blades, fishing line, and Goo Gone gel will be your friends for this task.
