What year? I could have some goodies coming for it :flipoff2:
Umm, WTF?!?! I bought a 2001 Hundy with 49k on it and you didn't tell me you have goodies coming for it! :flipoff2:
How difficult was this? I need to do it. Were you noticing any rattling prior to replacing them?
Rattles yes. But even after 20 years the bushings did not look bad. It was not a difficult job just time consuming. I spent most of the time drilling the old stuff out. From there it was pretty easy pressing the new bushings in.
Do you need a hydraulic press to push in the new bushings?
A press makes it a really easy job. However, you don't need a 20-Ton press.
2005 LX. I'll have to check the site and see what you've got. It is planned to be my wife's DD. We will see.
Damn. Very little to date for the 2004+
For YOU I do...but still working on it. I saw the 49k and figured it was raining corn swill again.
This 50,000 ton press came in handy to get the old bushings out...
Just doing the front control arm bushings. Also picked up some spc rear lower control arms.
This Saturday I replaced:
-Distributor cap, O-ring, and Rotor
-Spark Plug Wires
-Oil pan gasket and drain plug gasket
-PCV Valve and grommet 12204-35040, 90480-18001
-Air filter 17801-61030
-Vacuum lines 90999-92003
-Oil, and oil filter
-Coolant flush
-Replaced radiator cap
-Wipers
-Checked belt tension specs (adjusted per FSM torque)
-Shampooed all the carpeting and did a real nice cleaning.
-Serviced grease zerks
-Drained/refilled diff oil 90W Royal purple
-Took it into the local auto shop to get it re aligned (worth the $80 in my opinion)
Future plans:
Replace diff gears with a different ratio (to be decided)
Old man Emu lift kit (Medium)
Valve adjustment.
De-smog
Cat delete
Add a second battery
Buff the body
Replace all windshields (pricey)
Replace all carpet and upholstery
Rebuild power steering pump
Hunt for some discontinued parts
Pads, rotors, calipers (NAPA)
Deck/speakers
Replace tires
