last weekend - regular oil change before going up to the Hot Rod Power Tour in Joliet, IL (didn't see a single land cruiser up there, but was there for my Uncle's panel truck)
today: rear diff and transfer case oil change - hit your bolts first to break up the rust + liquid wrench/pb blaster + time + impact and I finally got the fill plug on the rear off - t-case was normal/easy.
next week's plans are a transmission complete drain/fill and that should complete my baseline fluids, and hopefully I can get a wheel alignment - I suspect the lift needs some caster correction though.
got it back from the shop a little over a week ago where I got all new front brakes (rotors, pads, calipers, fluid flush), power steering line replaced, compression test done (found an old maintenance record from the first owner about 12 years ago that showed issues there - none now), and a new right hand knuckle because someone previously used the wrong bolt and rethreaded it to 1.5 - helicoil failed as well. O2 sensors - not done, I have a leak in the catalytic converter and the muffler is also shot, so I'm onto a new exhaust altogether, luckily I have a guy who specializes in Toyota exhaust near me 304 stainless, above frame is what I'm going for once he's back.
Ordered slee rock sliders and skid plate a couple weeks ago.
Guess it's a good thing I didn't get into SAS in time; I still plan on being on vacation that week though and might be out there anyway.
Got this from my daughter at Echo Lake (10,600') part way up the road to Mt. Evan's. She reports the truck performed beautifully the entire weekend trip. The 91 year old original owner was thrilled to see in back in different mountains.
Thanks again to a ton of you for helping me get the truck baselined and ready for adventures. It was a ton of fun and seeing it in regular service is a delight.
Special thanks to:
@Malleus
@Kernal
@Rifleman
@Broski
First real time “out” since bumping up to 37s. 2” extensions in the rear seem to be perfect. 1” in the front seemingly could go a little longer. Wheel tire combo is right on the money.
What is the rest of your suspension, or do you mean those extensions are on the stock springs? That can’t be right.
Prototype trail tailor slinky springs up front 6” dobinson shocks. OME 863J in rear with L shocks. EIMKEITH RAM. “Spacers” I am referring to are spacers lowering bumpstops.
What I was thinking bump stops are what you extend.
Really like my rear Trail Tailor rear springs 🤷‍♂️ if you decide to get rid of the fronts let me know.
Damn I didn’t know there were rears floating around…. Im sure a matching set would be magical
Have you ever heard of "spider sag"? Despite working with sound systems for more than 30 years, somehow I never have. Well, today I rotated the drivers in my home audio speakers 180 degrees, and it's like I bought new speakers! I can't wait to flip the speakers in my 80 and see if they sound less like an '80s transistor radio.
I was very confused for a minute until I realize in which direction you were rotating them 😂
Special thanks to:
@Malleus
@Kernal
@Rifleman
@Broski
Very nice! Let her know I'm still planning a climbing trip next year...we need to talk.
Half molle on back window for fire extinguisher and first aid kit, will get better fasteners for the small stuff. Also had to get a new battery and put in a new hood liner. Mine was really deteriorating. Also got my fun back badges back on after the paint job. Lastly replaced the broken back louver that’s been there since I bought it 7 months ago. Now to get that leaking rear main seal fixed!
Fairly certain that rear bumper and skid plate are Ironpig Offroad. I don't know about the sliders, but it is very possible a one off slider built by them as well.
Yep
It’s an Iron Pig Off Road skid plate
Thanks guys, figured someone would know just from looking!
Finally needed my trailer, so got the 80 unloaded.
Pulled the front bumper and winch, I guess I'll start at the front and work my way back.
Core support looks great, condenser is a bit tired but will run for now. Nice mouse house in the frame.
You can warm up in their new gym!
