You doing both the high and low side?Got the transfer case split off the transmission and got the transfer case split apart and ready to get started with the re-gear!
I've been procrastinating doing this for months nowGot the transfer case split off the transmission and got the transfer case split apart and ready to get started with the re-gear!
Yes, 3.1:1 low range and 10% under driveYou doing both the high and low side?
I used JDM Toyota switches. If your 80 is pre-wired for seat heater switches they are plug and play. Not all 80’s are pre-wired. Lots of good threads in the forum. I'll link some below.Need to do this what heater pads did you use?
Where'd you source the switches
That’s a nice clean install and a great use of the ashtray space.Finally finished wiring up my gmrs radio. I don’t care for the dinky ant it came with.
EDIT:I used JDM Toyota switches. If your 80 is pre-wired for seat heater switches they are plug and play. Not all 80’s are pre-wired. Lots of good threads in the forum. I'll link some below.
The switches I bought on eBay. For the seat heaters you can use any you want - Amazon, eBay, whatever. I snagged a kit from leatherseats.com. The kit has everything you need, including switches and relays, to install in any vehicle.
Actually if you don’t mind using non-OEM switches, that kit from leatherseats.com would be the easiest path forward. It includes relays, switches and everything for any car / truck install and any seats. But I wanted to use the OE Toyota switches so I cut off all of the relays and re-wired them.
The threads below were all helpful to me for various reasons so I bookmarked them. My advice to you would be to remove your center console and look for the plugs for the factory switches. My understanding is this applies to 97 FZJ 80s, but not the LX 450s. If you have the plugs, then do what I did and get the factory switches, buy any set of seat heaters, and cut the relays off.
If on the other hand, you do not have the pre-wired plugs for a factory switches, then just buy a complete kit that includes switches and relays and install that instead. Don’t bother with the Toyota switches. They just add more complication if you’re not already pre-wired.
That’s my advice.
Helpful threads:
Seat disassembly / reassembly
Another seat disassembly / reassembly
Replacing seat bottom foam
Seat heater wiring
‘97 FZJ80 seat heater wiring
Seat heater installation
Seat heater switches
Not sure what happened here but this picture makes a lot more sense than the ones in the notification email.I installed the TEQ Offroad under hood lights. Well worth it!
User error. You saw my bald spot!Not sure what happened here but this picture makes a lot more sense than the ones in the notification email.![]()
me wantI installed the TEQ Offroad under hood lights. Well worth it!
Nice! Was this a pretty basic/straight forward install?I installed the TEQ Offroad under hood lights. Well worth it!
I'm ordering one. I was going to design my own, but for $55, that's done and done.me want
Same. Ordered.I'm ordering one. I was going to design my own, but for $55, that's done and done.
Extremely straight forward. There are two power switches. A hood detent and an inline on/off. I take a photo of where I drilled the hole for the hood switch. I wanted to make sure there were no a/c lines running underneath to conflict with drilling a small hole. I spent more time wiping down with acetone than I did installing.Nice! Was this a pretty basic/straight forward install?
