More photos of subaru in driveway please!
Which one?More photos of subaru in driveway please!![]()
If your there tomorrow through the weekend, I might see you.Not the weekend but……
Windrock.
What belly plates are those?Armor prep for Rubithon, clearance test, quad conversion.
Looks like huddexpoWhat belly plates are those?
I think that's the original Eaton clutch.
huddexpo.com
Blasted my axle housings to prep for paint.
View attachment 3652429View attachment 3652430
Got the head and some parts bolted down
Lost about a half gallon of coolant yesterday in the parking garage at work from the T-stat housing. Turns out I forgot to remove the old paper gasket that was stuck to the top of the housing. Took that off tonight and scraped both sides of the housing as best I could and put back the new OEM paper gasket. Can’t tell if that did the trick because I’m out of coolant and it was too late tonight. Will get some tomorrow and test it out. Hopefully it works and I don’t need to take it off again and redo. I did it without draining the coolant and it was a bit messy. (I did suck out about half a gallon from the radiator using a turkey baster.)View attachment 3650417View attachment 3650418View attachment 3650419View attachment 3650420Drained coolant and replaced heater control valve, lots of heater hoses, including the two that attach to the oil cooler (one was in bad shape which is what precipitated the project). Also did the thermostat and 3 of the sensors attached to the housing. Broke air cleaner hose No.1 trying to remove the hose that connects to the intake manifold behind the IAC valve. The rubber just separated where the metal nipple goes in. Glued it back together until I can get the new part and it seems to run ok. Fix one thing, break another seems to be a general rule for these trucks.
The old coolant actually looked great. The PO had the radiator and upper / lower hoses and water pump replaced in 2019. Everything looked pretty clean. The o-ring gasket for the t-stat had seen better days but everything else was in good shape.
I didnt sign up for GSMTR, really wish I had. Heading back to Columbus tomorrow. Airshow on Saturday. Next year i am definitely going to GSMTR.If your there tomorrow through the weekend, I might see you.
Still leaking from the T-case housing. I’m wondering if the OEM paper gasket getting soaked with coolant compromised its effectiveness. Picking up a new one tomorrow and may throw on some RTV as a belt and suspenders approach.Lost about a half gallon of coolant yesterday in the parking garage at work from the T-stat housing. Turns out I forgot to remove the old paper gasket that was stuck to the top of the housing. Took that off tonight and scraped both sides of the housing as best I could and put back the new OEM paper gasket. Can’t tell if that did the trick because I’m out of coolant and it was too late tonight. Will get some tomorrow and test it out. Hopefully it works and I don’t need to take it off again and redo. I did it without draining the coolant and it was a bit messy. (I did suck out about half a gallon from the radiator using a turkey baster.)
I assume you meant T-stat, not T-case.Still leaking from the T-case housing. I’m wondering if the OEM paper gasket getting soaked with coolant compromised its effectiveness. Picking up a new one tomorrow and may throw on some RTV as a belt and suspenders approach.
Yes typo. And yes I replaced that one. I suspect the problem was I missed the old square gasket, it caused a bad seal and allowed the new one to get soaked, and the new one is not making a good seal. I torqued everything to spec so not sure why coolant would still be coming out the housing.I assume you meant T-stat, not T-case.
Did you replace the round rubber gasket that sits on top of the thermostat?
The housing could be warped. You could remove the upper housing and lap it with sand paper on a known flat surface. A couple passes will reveal if the surface is warped.Yes typo. And yes I replaced that one. I suspect the problem was I missed the old square gasket, it caused a bad seal and allowed the new one to get soaked, and the new one is not making a good seal. I torqued everything to spec so not sure why coolant would still be coming out the housing.
