About to do an oil change and send in the sample myself.Also got my Blackstone oil lab results. Not bad I don’t think.
Order a catch can for the vent tube off the black box. You can thank me later!Finally getting started on the engine swap prep work. First up was the swap out this input shaft on the NWFab Blackbox and reclock it. I’m sure it’ll be back apart again for final adjustments.
View attachment 3567426View attachment 3567427
I've had nothing but great experience with Victron. Worth the $Did you choose the victron Orion smart dc-dc charger? I am trying to find the right one for my setup. I want to replace my flooded lead acid secondary battery mounted under my hood fastened down with the delta battery tray with a 100 ah lithium battery. At the moment I have an isolator to separate my starter battery and my secondary.
Thanks for looking out. Already plan on controlling an external pump with a temp switchOrder a catch can for the vent tube off the black box. You can thank me later!
thanks. do you think I will have any issues with heat mounting under the hood?I've had nothing but great experience with Victron. Worth the $
Nothing to worry about… been running my solar controller for 2 years under the hoodthanks. do you think I will have any issues with heat mounting under the hood?
Mine has survived 40s, being completely airborne a few times and dropping on a lot of rocks. That said, I also run anemic power through it.Thanks for looking out. Already plan on controlling an external pump with a temp switch.
Should be interesting….or exciting to see if the blackbox (or the tcase) will survive with 3x the stock power level and heavy tires.
Did you fasten the console with all 4 bolts?Got a subtank console painted, installed, and wired. And it actually works with no smoke.
In other words - are there 4 nuts even though it didn't come with the console from the factory?
forum.ih8mud.com
