Those were just place holders to get the nozzles where I wanted them. :flipoff2:
When you're moving forward and the fan is pulling air through the radiator, will the misters even get the radiator wet? Shouldn't they be on the front of the radiator? Did I miss something?
Got the attic rack and and a rear cargo light installed . Details in my thread here...
https://forum.ih8mud.com/threads/got-tires-finally-feel-worthy-to-start-a-build-thread.621867/page-2
Yup you are missing the radiator, the radiator has been installed yet. What you see is the AC condenser.
Again, you folks are looking at the condenser. The radiator wasn't in yet. The misters are mounted in front of the aluminum radiator. If you look at this photo, in the space in FRONT of the radiator, you will see the four misting nozzles.
cleaned about a half gallon of spilled milk from the rear cargo area...FML, I had just taken the damn weathertech liner out for drawer measuring a few days before.
carpet dripping on the deck rail hoping to dry out, sound deadening material ripped out, milk mopped up, new sound materials back in
the weekend needs to get better...quickly
I certainly should have looked closer. I like the setup!
Misters look good, just make sure that you use plain water and not windshield washer fluid. :)
So I've been researching this like mad. Most windshield washer fluid, Methanol, is ~55% water and ~45% alcohol. The alcohol has a 16x evaporation rate compared to water. When all of the engine fluids were tested on a 1000deg heated pipe, everything tested flamed up immediately. Washer fluid wasn't tested because it would evaporate before it had a chance to ignite.
So then I was thinking about what is going on that could cause it to ignite. Since it is atomized (misted) it should ignite easier. But it is all buffered by the radiator. Nothing to potentially ignite it.
By using Methonal I would enjoy more evaporative cooling as well.
I've yet to find a single case of washer fluid igniting in the car.
I'm still trying to figure it out so any further info would help.
Installed some matte black vinyl to reduce the glare from the lights I installed on my new Baja Rack. Add in the dual battery system Torfab installed this week and I'm getting close to final overland vehicle status.
I'm interested in knowing more about that vinyl, looks like a good way to get the job done.
I'm torn on this. I did the rustoleum matte black thing on my 60 and I love it when the sun hits it just right. I keep going back and forth between doing this on the LX. I think if I had a roof rack with lights my mind would be made up.
Last few weeks prep for Moab family vacation: Cap, rotor, cap dust ring, plugs, wires, valve cover gasket, spark plug tube gaskets, throttle body clean and gasket, intake manifold upper and lower clean and gaskets, new coolant hoses, Toyota red coolant after full coolant system flush with hose then fill/run engine/drain with distilled, phh bypass, egr vsv, egr modulator, egr gasket, silicone vacuum lines, hand throttle, fan shroud, AC tensioner pulley, new black loom/covering for O2 sensor wiring harness that runs behind block on top of bh/tranny(pita), reinstalled pressure washed carpet, new carpet pad, amp, sub, head unit, rear door speakers (fronts already in a couple months ago), power and ground ran from battery to rear ds quarter for aux fuse block, 12 lines ran from rear qrtr to behind dash for offroad light switches and solenoids, new exhaust hanger need led to a new Magnaflow muffler installed by muffler shop, rear driveshaft balance (new u joints a couple weeks prior), lubed driveshafts, rebuilt injectors, fuel filter. A month or two ago did 1 ton tre's and 4x4labs hd draglink and tie rod, lifetime alignment at Firestone. That is most all of it... Stoked to head to Moab next week for awhile!!
Wasn't worried about ignition. Methanol is hugely corrosive to thin aluminum like that in the fins on your radiator. It attacks the aluminum oxide that forms and protects the outside of the aluminum and once that is gone corrodes the thin aluminum quickly.
