Random tandem issues. Newish charcoal canister. P401 and gas tank pressure. Heat, altitude…Charcoal canister issues?
Everything went away Sunday at some time driving out.
I suppose that valve thingie under the manifold is starting to act up.
Before I put these back together, is it advisable or recommend to use a dielectric grease on the connectors? Anyone done this? Thanks.. dgRebuilt my rear elocker last week, typical issues such as lose magnets and general crud. Tested with a battery and works great. However, could not get to work using the switch. Anyhow, found part of the problem today. The connector under jack location was all corroded. Pulled apart and pins were all green. Cleaned them up, but found pin 12 just gone… anyone know where to get these pins? Also, when finished, should I use some dielectric grease on this connector? Pictures are after some cleaning, I’ve got more cleaning to do..
If its going to get wet its a good idea to put dielectric grease in there and its easy to clean out if you need toBefore I put these back together, is it advisable or recommend to use a dielectric grease on the connectors? Anyone done this? Thanks.. dg
Yes, that's how the top half is supposed to fit. The bracket keeps it from running the pillar.eBay Snorkel Install. Was hoping it would be a Safari knockoff w/ lettering on the side but no luck.
I feel like I got the snorkel pretty flush to the fender, is the upper half supposed to be that far away from the column? I couldn't really get it closer unless but maybe I was doing something wrong
Sad!She shouldn't squeal anymore
This is SheChanged out the idler/adjustment pulleys, tightened belts. She shouldn't squeal anymore
Can you fab a mount on the side of the can holder so the boards are perpendicular to the rear hatch? I think @Box Rocket did something similar.Finished up building the NWTI jerry can holder. Made a mount to attach it and hold the recovery boards. Now I can add the license plate light and backup camera. After checking the visibility, I think I'm going to keep the boards somewhere else until I'm offroad then put the on the mount for quick access. That or just not worry about who or what is behind me unless backing up but that's why the camera is there.
I've found that Bosal mufflers have a little better quality than the Walker brand.I've been waiting for a muffy for months now... just got this from Summit Racing
WLK-54223 QUIET-FLOW3 MUFFLER ASSEMBLY
Unfortunately, we have just been advised by the manufacturer that this item is no longer going to be available. Due to this new information, we will be unable to supply this part.
Might be a different story from local OoOoOReally's,,,
