Nicely done!! There's absolutely nothing worse than rust. And it's the only thing that we always pretend it doesn't exist or that it will go away if we just ignore it. You saved your LX
Thank you! Hope it looks somewhat decent when I'm all done. lolNicely done!! There's absolutely nothing worse than rust. And it's the only thing that we always pretend it doesn't exist or that it will go away if we just ignore it. You saved your LX
I used a bondo self adhesive patch and bondo. Here is what it looked like a few days before. Seeing it that bad is what prompted me to take acion.Did you weld in a piece of sheet metal for the gap? Do you have any before photos? I have some rust bubbles at the top of the window and only a couple small ones at the bottom, want to know what I should expect. Window seal is in shipping now so Ill tackle it soon.
And??Tried out my new super slim foldable BBQView attachment 2562227
Yep, time to replace. Just pull tire and mud guards. Can't remember if turning right or left helped. In reality, it was not that bad, at least not as bad as changing the high pressure hose on the power steering. If using silicone, it will be very tight and the toughest part of the install. Heat it up first and see if that helps, if not, use SIL-glyde as a last resort. I don't like using it unless absolutely necessary, if it is easier to go on with it, it is also easier for it to come off and leak...Time to pop my cherry - replacing my cheap China starter while im at it View attachment 2562388
What's with your hood? Not trying to be rude, just wasn't sure if there was something going on to explain the weird fitment.Little wheeling outside Winston NM & Socorro NM
Ending at 11,000 feet at the observatory
Lol i leave it cracked open when out on the trail just for better airflow.What's with your hood? Not trying to be rude, just wasn't sure if there was something going on to explain the weird fitment.
Years ago I used to have to prop my hood open with rocks on long grades in the desert.Lol i leave it cracked open when out on the trail just for better airflow.
Dang. That's some dedication.Years ago I used to have to prop my hood open with rocks on long grades in the desert.
Nice rig, real clean and looks taken care of. What tint did you have?- swapped 3rd row for leather seats, 2nd row still searching for. realized the '91 and '95 use different seatbelt latches and 3rd row in '95 i guess only has buckles for 2 so simply swapped the '91 receivers in and maintained 8 person seating.
- replaced cracked sprayer reservoir and fixed rear sprayer not working (line in rear near jack was submerged in water and mold made its way into tubing through the 1-way valve coupler)
- driver door liner, previous owner many years apparently had just hacked it out
- mounted some period correct ipf flood lights to bumper
- made adapter for license plater to get rear carrier all complete, added bumper tow receiver because i lost my tow when adding the rear carrier.
- installed front hd tie rod assembly
Well one try is hardly a good test but my initial impressions are very good. Certainly handled the cooking part very well. No twisting or buckling with the heat. Still folded nice and flat.And??
Finally have some time, space and materials to start several projects that are somewhat intertwined. Tore out the interior, headliner and started making space under the hood. Projects starting on:
I have been accumulating parts for the last year just waiting for when I had some time to start. So, second day tear down, cleaning starts tomorrow...
- Sound deadening mat, sound deadener, heat insulation, new mass backed carpet. Cleaning what is not replaced,
- Refurbished front seat belts,
- New head unit and amp
- New hydro boost brake system (courtesy Matt Sweeting's Speed and per @baldilocks writeup 80 Series brake hydro booster conversion installed )
- New power steering cooler and quarter panel mount courtesy @NLXTACY
- Dual battery setup
- Switch-pro install
- New LED off road lights
- Fix rattling sunroof and use @jonheld writeup: Sunroof front and rear drains clear but...
- Puma mount (courtesy @LandCruiserPhil )
- Bunch of other miscellaneous stuff
