New manifold and new studs and it’s driving again! Now I just need a radiator and a transfer case
Haha good luck on your radiator! mine was tuff!
It's been replaced with a brass unit, I am hoping the local radiator shop can repair it.
. Whats wrong with your transfer case?It’s growling at me, i believe the PO ran it out of fluid. It’ll probably go a while longer but I am going to pick up a used unit and throw it in and then rebuild this one and put reduction gears in there.Thats what I put in mine. I think my old 1991 (made in march of 1990) had the original radiator in it. Wish I could have found an OEM one. No longer available. Whats wrong with your transfer case?
Before the "work from home" instruction was ordered I started to make a list of everything on my rig that causes even the slightest ripple of annoyance. The plan is work through the list when I am grounded so as to reduce the boredom.
Top of the list was stopping my camping gear rattling like mad so I made a set of drawers. Each drawer has a separate compartment for each piece of camping gear.
All nicely laid out for ease of access.
Ball bearing slides with soft close and a built in lock mechanism of sorts.
Covered them with same cheapo carpet stuff from Home Depot as I used on my KISS drawers. Pretty happy with the end result..![]()
The little compartments are made out some craft wood (I think Poplar) i picked up at Lowes. Pretty cheap and very light..What did you make the compartments out of? Thin wood?
I made a trip to Greenville this weekend (4 hours from home) for a test for my job. On the ferry (I live on an actual island only accessible with a car by boat) I noticed a drip from close to the power steering high pressure lines. I thought it was my high pressure line. (witch has been leaking too) Turns out its the radiator. it leaked out probably 2-3 cups. I toped the radiator off with some water at about half way to my destination but its back where it was when I noticed it. Recently replaced the thermostat (Not leaking) but I think that caused the 30 year old OEM tank to leak.
then turns out the radiator was the least of my worries.... That trip to Greenville from Ocracoke and back was been nothing but hell. I blew a break line on the way back. Its very unsettling when you have to stop at highway speeds and feel the breaks travel to the floor.... thank god for e brakes. and of course its a hard line section that runs beside the gas tank and frame rail almost the length of the fj80. turns out a half inch long section was rusty just in a spot where its not noticeable. Then at the auto zone (to get fluid so I could limp home) The car did the whole cranking cranking cranking cranking cranking.... it did not start. I did get 25 feet of break line but now the car refuses to start!. it was not the EFI fuse I have a spare. It started 30min later and I have no idea why it decided to. I had just found a tow service. The fuel pump is new. previous owner replaced it. and I can confirm it because I have been in the tank to replace the filter on the end. maybe fuel pressure regulator or the coil is not working properly? I blame Friday the 13th.
Today Saturday I am flaring and replacing break lines... I have one more fitting to take off. Then to bleed the breaks. Radiator is still on the way. Hopefully that will be ok when it comes in. I purchased new front window regulators at the same time! still don't know why it would not crank though. I think fuel pressure regulator maybe? I don't think its the efi
Big fj80 repair weekend! Gotta keep my old gal going.
Tried to talk the Missus into taking the kids out there today. I figured this is the perfect time to take a vacation and, it’s about as socially distant as you can get around these parts.
