Finished my 2nd birf overhaul but this time added Aisin HD part time hubs, Trail Gear spindle lock nuts and the infamous 30lb spindle nut torque mod. Torqued all my steering arm studs to 60lbs (quite a few were loose) and swapped out a discolored wheel bearing. The result is such a noticeable difference over the slightly loose wheel bearing I had after the 393 trail shook my front end apart in December.
FSM wants to see 71lbsView attachment 1427896 Found this sweet little spot in Moab. Had to pull in and grab a pic. Blended right in hahaha!
Lots O' tires on the roofs...![]()
That was the first thing I noticed.That was the first thing I noticed.
I battled placement of my 2800. The locations I thought of were behind the center console. To the side of the center console if I gave up the cup holder, or below the single din stereo.
No detachable face. That's the complication.I'd vote rear hatch. I'd like to hear some feedback on the Diamond mounts or some others that would mount back there.
I mounted mine up front using the Gamiviti mount, and unfortunately do not like it. It flops around a lot on the trail. (Obviously this depends on your antenna too...) . However other members said they liked it!
Oh and the actual radio you are asking for... ah. Hmm. Does the face come off?
Where did you mount it?I have the same radio. Good clear sound.
New timing belt, waterpump and rear heater delete.
Back n '88 I spent 2 weeks in Ibiza partying with three military buddies. Awesome beaches and all night clubs!New timing belt, waterpump and rear heater delete.
Did you adjust the open/close scheduling of the thermal valve on the fan clutch?OG black hub clutch mod...Summer's coming!
Haha. Not yet. Still gotta take the test.Is your handle KBXRKT?
