Like BOSS....!!!We Boated!View attachment 1425868
Hahaha!^^^On my best days... I will never even be close to this manly!![]()
Any tips on this? I am gonna start to attempt my replacement this weekend....Began the tear down to replace my heater core. Geez what an ordeal only got about 70% there. Had to stop
Before the BFH and a Sawzall were put to use.
Yes Sir it is.Hell yes. Is this in east Texas somewhere?
I used one side adhesive foam weatherstrip from local hardware store when rebuilding the cab HVAC tubing.Tips.... its all pretty filthy and all the foam seals are toast and need to be dealt with in some way, haven't figured that out yet..
Thanks for the tips...I am pretty handy with the wrench, just never taken off the dash or done any of this type...(installed new exhaust system, Lift, suspension and sway bars.) Most likely, getting started this weekend...not daily driver, so I have some time. Let me know what you come up with on the foam seals. Thanks againTips.... I don't really have any, other than its a process. In my case the dash is 95% removed to get the unit out
that holds the heater core. I removed the AC section as well, You'll have to discharge your AC mine hasn't worked in 10 years so it wasn't an issue for me. But the main thing is that most if not all the heater core parts are unobtainium from Toyota or anywhere else. If your core is leaking you'll have to take it to a radiator shop for a rebuild. And have the brass tubes brazed back onto it. It's a very doable job have patience and keep track where everything goes. I really don't know what level of skills you have turning wrenches and the time you have to dedicate to the task. If this is your daily driver, this isn't something I think can be accomplished over the weekend. Unless you have all your
parts together and ready to go. One other thing everything I've taken apart regarding the heater core, ducts and odds and ends are getting a good cleaning its all pretty filthy and all the foam seals are toast and need to be dealt with in some way, haven't figured that out yet..
Also, make note of the sequence of disassembly. When you go to reconnect and reinstall things, some things have to be done in a certain order, or you'll have to go back and undo a few things in order to continue. Don't ask me how I know.One tip. If you've pulled off all visible nuts and/or bolts and the piece will not come loose take a closer look for that one nut or bolt you overlooked. Overall not that bad of a job to dismantle the dash just time consuming.
Ok one more tip. Take photos of how the small brackets under the dash are oriented and of their location.
J,
Looking forward to pics post install. Ready to tackle my suspension now that my knuckles are done.
Untitled by Greg Fisicaro, on Flickr
