I have been working on the cruiser and driving it, but I haven't posted in a bit. I got my 6
° shims from
@RevISK a while back and put them in the next day. I pulled my 4
° shims out and put them in my buddy's HJ60. It didn't take much time at all, and both of us have much better steering now. I can relax while driving and the wheels aren't chasing every groove or rut in the road, its kinda nice....
The PS Pump died after whining and putting up with some abuse... I put a remaned pump on recently so I just swapped it out at the local parts store free of charge.....I feel like I typed all this up before, but must have not actually posted
I'm going to need to replace the steering box, the casing has that rough spot I have tried to polish out a few times and it is also sucking in air from somewhere and the new seal kit didn't fix it. Its causing the whine and its causing an inconsistency in steering only with right turns, but its not great at higher speeds.
I swapped out my water pump on the LS for the Trailblazer one so the neck doesn't hit my intake tube, that was a bigger job than I wanted but it was a good time to get it done since I took the alternator, mounting bracket, and PS Pump all off to get the PS pump swapped out. The new water pump should allow a LS1 or LS6 intake if I should ever decide to do that and get back some hood clearance. It mostly is to allow the intake tube to set down lower and allow the hood to close.
After I replaced the original PS Pump I didn't get the pulley back in the exact position, probably only off by 1/16" but it made the belt start chirping, that was annoying because I had also gained the PS pump whine due to the box letting air in the system. So this time around, I got it right and that fixed the belt chirp.
I have driven the cruiser for a bit now with the box still leaking air and having a rough spot in it.....I am hoping the pump survives (its much quieter than the first go around)...but its a local parts store pump so it has a 'lifetime' warranty.... my plan is to track down another box first.....
Other than that I have just been taking the dog for rides to his favorite walking places and stopping at a local brewery on the way home.
