Toyuzu Fj60 (Rootbeer Diesel Build)
Bench bleed master cylinder x2
Okay Isuzu diesel guys. Are you all using all three water temperature hook ups? There are two in this picture, I accidentally broke the wire off of the top one. There is a two wire one on the other side of the thermostat housing on the drivers side.
I used the one wire sender from the 3fe in the same spot the one wire sender was on the Fuso tstat housing. This way the sender is the correct impedance for the gauge. Threaded right in.
I used a stock 2f water temp sender also, and Pacer stated, it threads right in. I also used a stock Toyota 2f oil pressure sender. Both stock 60 dash gauges work perfect.
I guess what I was asking is, which of the three in the thermostat housing is the right one to use. There is the yellow wire one in the picture on the bottom side of housing and then the one pictured at the top with the wire broken off. What is that one used for. Then there is the one on the other side. Surely you cant have all three going to the water temp gauge.
Here's mine - It has slit loom over the wire and threads into the same hole as your Isuzu sender.
Okay Doug, looks like your upper one has a plug in it. What about the one on the drivers side where the heater port comes out?
Not much to report. Did go on a 10 mile round trip test drive with a stop at the first five miles to stop at a friend's house and wire up the ARB Compressor and switches.
So it's gonna be at GSMTR 17? :grinpimp:
Fo sho, she'll be there next year. Hope to make our little club ride Oct 22nd to Golden Mountain. Then on to STLCA ride in November to Windrock
Got my fan shroud cut apart, extended, welded together and then did the fan shroud modification. Pain in the butt, and it's painted and back in.
Drove her over the weekend, about 120 miles total. Coming home from my sons baseball tournament
HELL YEAH the turn signals work!! :grinpimp:
My son couldn't believe that the turn signals worked. The only light that doesn't work is the passenger side front driving light. Not bad for 32y/o wiring harness.
