- Joined
- Jul 22, 2012
- Threads
- 639
- Messages
- 17,563
- Location
- Winter Park, Florida
- Website
- www.cruisermatts.com
You just gotta work through the issues man. You'll get through the it, mine is being the same way right now.
Going to check the dealership first and see what a new one cost. If it is outrageous, I'll look into getting one made.If no joy, have the hose company make one, or use SS braided hose and fittings and make it yourself.
It was the original line, had it on the motor before putting it in the 60. Just think it was an old line.Is that a fatigue crack just from being bent to accommodate proper positioning?
Good idea sir.I use a motorcycle brake line, banjo on both ends and an endless selection of lengths/fittings...
Has anyone used the TSM transfer case parking brake on a 60?
My experience with it was on a 40 and it wouldn't hold it at even a slight grade. Just not enough leverage in the design.
And you 60 weighs a LOT more then this 40 does.
What's wrong with your axle parking brake?
There must have been something wrong with that specific install then. When Tinker worked with TSM to develop the transfer case e-brake kits for the 60s, he made sure that they were set up to hold the truck on a hill. Check this thread out:
TSM Split Tcase Disc Brake Prototype #2
In my experience, the TSM transfer e-brake kits work well, not as well as the stock drum setup, but well none-the-less.
Interesting. Ryan still didn't answer what was wrong with his existing e-brake though!![]()
Have you considered a "line-Loc" type system?
Thanks Johnny. It was brought up in the TSM thread of using an 80 axle due to it having disc/e-brake. Then I would need to sell off my axle to do this and buy another ARB locker for the rear. I like the idea of the TSM, price is a little high, but this is due to someone doing the R&D. I'm torn on what to do, lol
You don't need to buy another ARB! You could easily buy an 80 rear axle and put your ARB diff in and sell the parts you've got left over. Although you'd then have to deal with the extra width.
TSM is a perfectly fine way to go and it'd be less work than swapping axles.
I do ..
80 rear is an awesome upgrade in a 60. You can re-use your existing diff.
Just put 2" spacers up front to account for the wider rear, you'll appreciate the extra width with the SOA height.
Lot of folks never bed in their ebrake.
I find if I bring the vehicle up to speed and drag it down to 10mph or so a few times when I replace brake parts the pads/shooes bed in to the rotors/drums.
Same process goes for the ebrake.
