Would a 15x8 allow disc clearance ?
FWIW - Here are my 15x9 OEM rims, with the OEM backspacing....
Here are those rims with a set of 32x11.50's
I like the parking brakeRustoleum smoke gray will get them close to OEM gray.
I like the parking brake![]()
I used the house brand Massey Furguson Grey from Tractor Supply. The paint, once cured, has been extremely durable. Much better than any rustoleum, duplicolor, or krylon I've used.
Yep. Pushing it in and out of the carport can be tough on wheels.
i like that, where did you purchase the rims? ideally i am looking for 16x9 with the tabs but i know i will need to fabricate it.FWIW - Here are my 15x9 OEM rims, with the OEM backspacing....
Where did you find these? Or did you have them made?FWIW - Here are my 15x9 OEM rims, with the OEM backspacing....
Wide Wheels in Calhoun GA did them.Where did you find these? Or did you have them made?
Somewhat off topic but still a wheel related question.
I found that US Wheel has 15 x 10 spoke wheels like I am looking for. (Part 70-5060) The back space is 3 3/4" and not the stock 3 1/2" spacing. If I purchase a set of those I will need a 1/4" spacer to make the wheel clear the TREs. I have a set of 1/4" aluminum spacers but I have heard bad things about aluminum spacers and hesitate to use them. Does someone make a steel spacer or is the aluminum trustworthy enough to use?
Last question. @GA Architect your wheels look to have an exposed joint on the inside of the wheel rather than having the joint welded. Might this allow water into the welded joint and maybe compromise the weld at some point? Can you still run tubeless or is a tube required?
Rims in a nutshell:
E-60 body color
61-67 black rims
68-72/73 gray rims
72/73 - 7/80 gray outside / black inside
8/80-84 white wagon wheels
