Hello,
I've notice the most famous on going leak on my cruiser. The rear seal on my t-case. Now it's time to fix it.The t-case has been there for 35years and has held up like a champ, I think it's time for a complete rebuild(front flange on the t-case is wobbly=bad wheel bearings?). I've gotten this far with common sense and before I make a mistake I would like some advice from the experienced. I'm not a mechanic by any means.
What's been done some far:
-drained what was left of the gear oil.
-disconnected on linkage to the vacuum t-case, and column shift linkage on the trans.
-jacked up the rear end for elbow room(fit the braker bar)
-taken everything bolt to the t-case off.
-seperated the e-brake as a unit. it's in good working order, so i just set it aside(don't fix it unless it's broken). should I order and install a replacement kit for my e-brake while it's out or just wait until it goes out???
-unbolted the 1inch bolt the trans shaft.
-crack and loosen the five bolts to the trans.
Now I've got some questions.
I was told to pull both the t-case and tranny as a unit to avoid the trans shaft from falling out. Is this true ? or can i seperate the t-case and trans from underneath my rig.
I read in the haynes, it mentions about rev. light connection. I need to disconnect some wire from the tranny or t-case. If so, I don't see them nor feel them awhere in the general area. Oh yeah, did I mention, I'm doing this all from beneath my rig. Is this a bad idea ? should I take the time to take off the trans cover. What the advantage and disadvantage?
I've got a jack supporting the t-Case right now as I wait for further guideance. All five bolt to the trans are still attached.
I've been looking at a lot of threads about t-case's. I'm just not to clear about the seperation procedure.
thanks in advance!
thanks in advance!
