Thoughts on wheels
Keep the steelies or switch to KDM's
  • yes
    Votes: 7 63.6%
  • no
    Votes: 4 36.4%
  • Total voters
    11
Houston, Texas
Guys, i have a opportunity to swap out wheels and tires on my 72 FJ - Currently running stock steelies (off white) with just regular tires. Have chance to put on these black KDM XD Enduro wheels, which will require at least 1 inch spacer due to 4.5 inch backspacing........
What are your thoughts? Obviously i know there are a ton of opinions but was curious. Also 2nd question would be safety of "spacers".
I will not be getting rid of the steelies as i have place to store them in case i ever want to switch back. Mind you i do like the look of the black KDM's.
Thanks,
Brad
I prefer the look of stock wheels and hubcaps, but you end up very limited on tire selection. Less you fork over some coin for 16's, even then the width of 16's is a limiter too... Eventually my 80 will get a set of SCS's and the 40 will get the stock 80 wheels, as seen in this thread.
Photo courtesy of @DSRTRDR ...
I am biased, but I would go with stock wheels but powder coated black and no hubcaps --a very utilitarian, tough look in my view
I don't like black painted alloy wheels, and don't like spacers on the front (changes the steering scrub radius). Definitely a vote for stock steelies.
I like the fronts but not the spacer. Get a wheel with proper backspacing or better yet, stock wheels in a darker color (gray/black) on 33x10.5 like mentioned above
spare tire has a different thread pattern, though :confused:
