The Ultimate 80 Series Parts Discontinued Thread
Status
Not open for further replies.
Supercharger belt:
PTR30-60970
Discontinued.
Supercharger belt:
PTR30-60970
Discontinued.
View attachment 2697783View attachment 2697784
Dang. I had ordered 2 in early April from Toyota that did finally arrive, but in the interim I had found the Dayco that was originally on mine when I purchased it 16/17 years ago and retrieved the part number, the identical replacement worked for the past 6000 miles,
just have to get past the country of manufacture!
I don't need a new short block on my parts shelf. But damn do I want one. Might be hard to get the purchase past the wife though, when it'd set me back just about what I paid for the car! :D
If you want to keep your 80 another 20+yrs buy it, now.
If not and your engine is fine, it’s a waste of money.
Cheers
It has been mentioned in the past that Collectors Edition badges are no longer produced by Toyota. In the past, I had a vendor in Israel that was making them for me but has since closed his doors. I have 2 remaining and believe the only 2 in existence. Costly but available
Mine looks like the milkyway with so many micro chips. I halfway tried to polish it. will likely try to do a better job in the future. i really like a good windshield and what i have isn't that anymore.
I feel your pain.
Mine is original but beat and leaks.
We put a new OEM in a customers last September, yellow coating on it. It’s super nice.
I wanted one for my Cruiser so saved the part number. Thought I had time still, ordered it a couple months ago only to find out they just went NLA.
Seriously bummed. 😑
Cheers
I've been using these filters (15601-44011) since the big can is NLA (15600-41010).
Are they NLA or on their way as the Dodo bird?
Is the cruise control actuator also NLA?
88002-60030
PartLocker Install Part
Wire, Floor (82161)82161-60042
Wire, Floor, No. 3 (82163)82163-60051
Wire, Frame, No.2 (82165)82165-60080
Wire, Frame (82164)82164-60012
Differential Lock ECU89533-60030
TOYOTA PIPE, HEATER WATER INLET, B 87208-60270 (Discontinued this is for folks who have rear heat)
all discontinued (If I am wrong, please state so and I can delete my post) Thanks
It appears that the "tuna can" for the air cleaner is NLA:
17703-66020
Mine is slightly rusty so I was looking to replace, now it looks like I need to wire brush and repaint.
I will probably be corrected, but the pipe for vehicles with rear heat isn't available is it? The only one I can find is with no rear heat.
I ordered one a month ago. You can still get them. It was like $30, mine came in a Denso tagged bag, if that helps you.
04352-60010 A343F rebuild kit is NLA, per Toyota. This is the full kit, with clutches and gaskets.
ditto for 04351-60090, gasket only kit.
Looks like it's time to examine the backward compatibilty of the 1st gen 100 series A343F transmissions. The rebuild kits are still available for them.
These haven't been available in years.
NLA: Front left turn signal.Signal Lamp, Lamp Assembly Front Turn Signal81520-60232
Still Available: Front right turn signal.Lamp Assembly, Front Turn Signal, Right81510-60362
I’m sorry- didn’t Toyota announce they would be bringing back parts for the land cruiser and the Supra line vehicles? Seeing things like the lamps being discontinued contradicts Toyota statement.
Either u in (make the parts) or your out (not making parts), like pick a side bro (Toyota).
Check this article on yahoo
Mechanical parts only, related to braking and steering. 40 Series only.
Status
