Insulated box, maybe even add an rv tank heating pad to the battery box, with a thermal switch that will kick on when the air temp hits 40. That way the battery stays warm and happy during the charging cycle in cold temps.
My broken handle fix…cut down and welded on a sacrificial chinesium wrench as a makeshift lever. Holding well for 8 years now.Awning largely survived the higway incident. Have a broken bracket and a broken lock/retract handle. Handle isn't a huge deal (annoying) but the bracket is bad news. Cast aluminum so I can't repair it.
Searching for parts now, or I might fabricate a new bracket entirely.
Also, not sure how, but the fabric popped out of the holder in the middle. Not sure how that happened.
Yeah, the old Zip-Dee awning on my '74 is long out of production, so desperate times led to desperate measures. My fabric is a "newer" '90's Carefree Colorado. Carefree makes good fabric if you are concerned with yours pulling all the way out from the center. Once they start to let go, a little wind and rain will finish them quickly.
So bad ass man! Awesome work and luxury!Rockingham this weekend. Good to have the awning back.
View attachment 3888621View attachment 3888622View attachment 3888623
And when you need more, you build a hinged frame and use panels as an awning. And they lay flat along passenger side of the trailer during driving.Amazon.com ordered, 6 panel series/parallel setup we go.
There definitely will be. I chose to put only 6 panels up because I can fit them all in front of the AC unit, the party deck will be behind that.Does this mean there won’t be a rooftop party deck??
