Be patient.
We "piggy" owners are a patient lot. Parts always take a while to get sorted out. Nothing but the best for our piggys!
Be patient.
Howdy! Ditto for me. I'd be glad to take 50'. The Arizona (dry) heat has turned most of my w/s into dust. Since "It Never Rains In Arizona", I just want it so my doors stop whistling when I am on the highway. It's so bad that I can barely hear my tires roaring!! JohnI'm in for whatever works best. Let me know so I can Paypal whoever is going to do the group buy.
to Heath the father of this sticky!;
kick back and let dry
stumbled on placing it on stretch...........then comes the bottom where there is no channel.........take the rubber weather strip and notice that there are quite a few little fasteners that we had to take out to get it into the channels............DON'T remove the bottom ones!!......keep the rubber on stretch/slight tension line it up while you are on your back and use your
.........any suggestions?, will post pix later........this is not a perfect match as originally posted, and there is no molded 90 degree angle for the corners?? .........original post by HeathRJ was part # JC Whitney ZX184879T post#1; on post # 19 Heath discribed the channel rubber as "Yes - I think the window channel is an "exact" match - as is the the weatherstrip that goes on the door. It even has a pre-moulded 90 degree corner. In JC Whitney catalog it is listed as a 1970's Toyota minitruck w/s and is a perfect match to the original." QUESTION.......did I get the wrong channel rubber or is this the new replacement; BTW the numbers are the same
this teaches me to proof read.............corrections........the back VERTICLE component of the channel has a lip that makes it very difficult to feed the channel rubber from above................the window regulator was very STIFF till I dry lubed the felt inner channel and seated the outer channel rubber VERY well........it works very well, very happy with it......kudos to Heath who started this sticky and to all the others that have added to itFound a low tech solution to the lack of grommets between safety knob shaft and door body to help eliminate the small but annoying rattling behind my ear....used some silicone grease on the shaft.......sourced from "Lowe's"; hope this can be of help!
Lou
