- Joined
- Oct 4, 2008
- Threads
- 193
- Messages
- 6,192
I like the toyota bed liner mat used as a cargo mat.
Do you normally take the top off of the sides when you remove it? If so how come?In the middle of reinstalling the hard top for Winter.
View attachment 1816698 View attachment 1816699 View attachment 1816700 View attachment 1816701 View attachment 1816702
Here is the photos of after my winch up grades. New control box cover, installed Raychem shrink wrap on the motor wires, used new stainless steel clamps, installed new boots on the motor terminals, and used stainless steel bolts to finish it up.
Yep, I painted the flip cover black...it was brown (rust)...Just me, "making it mine".![]()
Several updates and repairs are in the process. Due to a few coolant leaks, my rig has the front engine compartment torn apart right now. I'm in the process of replacing all the coolant hoses, water pump, radiator, and other maintenance items.
#1 - Unbeknownst to me, the radiator support rods were misaligned and my newish radiator couldn't move/vibrate as needed. Per the radiator shop, all four corners of the radiator (below the upper tank and above the lower tank) had stress cracks from the rig flexing and radiator not....Such is life, so a new radiator is getting installed. The support rods will be adjusted, realigned, new rubber bushings as well as rubber washers between the radiator & radiator U-bracket/housing will get installed.
#2 - Newish water pump was leaking out the weep hole...time to install the Aisin WPT-063 unit for my rig. Will install with new gasket, some FIPG, and cleaned bolts torqued to 27 lbs.
#3 - After I took the water pump off, noticed that the thermostat housing was leaking a bit as well. So I removed, cleaned it and the mating surface up, cleaned the newish bolts, installed a new gasket, some Toyota FIPG, and reinstalled torqued to 18 lbs.
#4 - Replaced the leaking old original 'zig-zag' heater joint at the rear of the engine with a new Toyota 87251-30200 joint.
#5 - Will install all new hoses and hose clamps. Going to use some constant tension spring clamps and some stainless steel ABA Safe Constant Tension Hose clamps.
#6 - Also, while I'm in there, I'm cleaning and painting the area as needed.
#7 - All new Toyota pink coolant will refill the system.
Merry Christmas and Happy New Year's to all...![]()
I made a system in my garage. I made it with unistrut and pulleys. I use nylon rope to lift it through the pulleys. I use a small warm winch to lift it. I made a platform from plywood and a pvc fence post that goes inside to hold my doors. One goes inside and the other on top. Once it’s up I have cables to connect it to take the load off of the rope.Yes, for the past few years when I have taken the top off, I have disassembled the upper side & roof. The reason, never had the head height or room to store it any other way. Now, with a 10' ceiling in my garage, I plan to install a ceiling mounted lift/pulley system.
ust to give you an idea.I made a system in my garage. I made it with unistrut and pulleys. I use nylon rope to lift it through the pulleys. I use a small warm winch to lift it. I made a platform from plywood and a pvc fence post that goes inside to hold my doors. One goes inside and the other on top. Once it’s up I have cables to connect it to take the load off of the rope.
I have a question relating to the top disassembly/reassembly. I have to do a fiberglass repair due to the fact that the PO installed an aftermarket sunroof. Was going to deliver the entire top to fiberglass shop but now wondering how hard is it to separate the associated parts from the top itself? This would obviously make it much easier to transport to his shop. Thx for advice.
Rick could you expound on #1 a little? The support rod installation seems like it would be something that even this 1 banana mechanic couldn't mess up. I guess not. And Merry Christmas to you and yours also.
I need to do this to my Warn. Where did you get the parts? Does Warn sell them directly? I have not researched yet. Thx and great work. PS I’m in GA too.
