Alright. looks like you do in fact have the intermediate rate springs. and they are the 75mm ones. The heavy rears are part # 7511.Thanks @Box Rocket for the comparison, the visual overlay is great! I've got 7498s on the front, and 7501s on the rear. It's got new Matsuba u-joints that I installed as part of the re-build, and I double checked to make sure I got them in there right, so it's got to be all about the angles (obviously).
The need for added caster is what worries me; I didn't get to measure it last night, but I know it'll make the vibes/angles on the front shaft worse. As it sits now, a DC shaft would probably cure it; the front flange is almost exactly pointed at the front t-case flange (nearly no angle on the joint), but from driving feel, it's got zero or negative caster at the moment. This will be a daily, so that won't work.
I did get the kit from Endless Horizon Outfitters, and I got ahold of them yesterday afternoon. They are sending some 50mm fronts out to try today, and some higher angle caster plates too. The response: "Let's figure this out and we'll worry about settling up once you're happy". Can't ask for better service. Honestly I didn't expect much help. They've impressed me every chance they've had.
We'll see where the 50's put it, and then tack on the bigger caster plates if that doesn't fix it, and then see what the driveline angles are, but I'm still lost on the rear... I hate stink bug...
If I end up keeping it where it's at, and get the caster in check, is there a way to keep from going part time? It looks like our trucks do sit very similar @Box Rocket. What does your caster look like, and what did you end up doing for a front shaft?
I've said it before, but I can't say it enough, Thank You all for your help with this, and for the community you all have created, it makes stepping out into the unknown (to me) so much easier!
With caster, remember you can have too much caster and that can cause vibrations and other issues too. I'd aim for something in the ballbark of 4* caster all said and done. Pretty sure that's close to where I'm at (I'll have to dig out my last alignment sheet to check). Even if you can get 3* caster it should be ok. I have a DC front shaft on my truck. I still get a little growl on decel that I believe is from a bit of looseness in the splines. Been that way for a few years without issue and it's hardly noticeable.
If your front driveshaft diff flange is pointed at the tcase, that's definitely going to cause some vibrations. A DC shaft would be the best solution IMO. If you use single ujoints the flanges need to be set to be parallel with each other. Are you positive that your driveshafts are phased properly? You'll get some wicked vibes if they are out of phase.
Glad Kevin is getting you sorted out! He's good and calling him was the right move.
There are definitely 50mm rear springs available. I don't know if Kevin has any in stock at the moment but they are out there and would probably be the best move for you if you don't plan to add bumpers etc that will increase the weight of your truck.
There's no reason you should have to go to part-time 4wd. This can get sorted out with the right parts and settings so that it works properly and meets your expectations. If you're working with Kevin at EHO he'll make sure you get sorted. Hopefully he has some 50mm rear coils in stock so you don't have to wait too long for those. But I'd stick with the Slinky kit if I were you. You'll be glad you did in the long run.
Do they make 50mm rears?!?! I was under the impression they didn't make them?
Yep, see above,
