Suspension Help!
@AutoCraft Aus
How much lift do you expect the slinky springs will provide if I had ARB bumper, 12K winch at just under 2900lbs at the front axel with me in it. The reason I ask is I'm really aiming for 2.5 inch of lift since 3 inches is too close to the lift height most people running into issues with. Plus a lot of caster correction setup is for 2.5 inch. I currently have heavies front and back with no complaints what so ever but do like the idea of having a little more droop since I'm already running 4 inch/longer shocks.
For 2.5" lift, you would need the 20mm lowering springs from slinky.
I'm joking, sorta. Lets all have a good time now.
Yep, that's a line I would not cross - but you have no problem doing so. Anyone reading them should note the time stamps and the concurrent forum posts thread.
I highly doubt that given the nature in which you have publicly posted, vs what you were attempting by P.M vs here in this thread. You left us no choice in our defense due to your conduct on this matter. How it appears in the thread here has no bearing on the request from us, as you were told, we dont do customer education by public thread generally. We simply tried to help the same way we would of had we seen an issue any other time, as a wholesaler, product designer, engineering and manufacturing. You didnt contact a retailer to deal with you at a retail level, and you seem to be surprised and upset by this.
Just because you are ignorant of the reasons for doing P.M or email only, [and in fact posted up some of what we asked after we asked for it....] doesnt make us wrong, its just our policy, and you have been living proof of why we have that policy, while you tried to go around the retailer who sold them to you, and contacted us directly.
Thankfully you went back to the person who sold them to you, as we had said was the best option, which would of been the correct action to begin with, and they could of contacted us if they required any further information. They would of known what we required to be able to educate the customer. They would of dealt with the customer.
Our focus was the potential issue, and customer education, your issue seemed to be we couldnt solve your issue with out information, most of which you ended up posting up anyway, rather than send it to us as requested.
Our replies are in response to your accusations, and public thread, you forced us to this position, and we responded with facts. We stand by our emails to offer help, educate you, and try and get what was required to assist you, despite your resistance to be helpful. For this you tried to throw us under the bus, so we had to correct your errors.
Cheers
@AutoCraft Aus
The 50mm version would give you the height you want at that load.
Maybe I will sell a kit after I dial in valving?
We did that about 5 years ago. We did CDC coil over for low speed adjustment, and the bypass for high speed. Custom mounts, fender cutting, moving air boxes etc is to much work to not maximise the set up with adjustment to be honest.
I can tell by looking you have coils to sort along with valving, to get it that point :cool:
View attachment 2091776View attachment 2091781
These ones are for a bigger/heavier truck parked next to the 80, but you get the idea. Plus, mine is a few inches longer than yours, pun intended.
Why don't you have those up on the website? If you did, I might not be in the previous predicament... would potentially have skipped coils alltogether. I don't mind spending money on parts that work right for me the first time. Keep in mind, I'm not a regular 80 series guy, I don't mind cutting things, and I don't have abs junk in the way.
BTW, your steering box is on the wrong side :flipoff2:
2 Bulls in a Bull pen refusing to give in to the other . They rather bleed to the death to prove a point.
OP still has coils that even with 1000 lbs on front are taller than mine sit with 100 lbs extra over stock. Definatly a different batch. Dobinson same issues.
Bigger + heavier truck
Your observation skills are fantastic! Honestly, I have no hard feelings. I'm good with getting some actual tech in here though, you in Darren?
I wanna see how the coilovers come together! I'm planning to build a set of "caster plates" (probably just re-make the radius arm mounts altogether) to get the pinion angle right, and then do a cut and turn to set the actual caster back to where it needs to be. Coilovers start sounding good if you're gonna do all that anyway...
@toyota guy, how long ago were your 75mm dobinson's made?
By the way, his truck has the same bumper/winch/battery combo as mine, and he has 1" front spacers. His truck sat .75" lower despite the spacers. I drove it a few weeks ago, feels nearly identical other than diesel power. His steering box is on the wrong side too.
I'll definitely post up the results in here. So far, the same king 14" short body Kings I'm using on my LX seem to be the ticket. 12" ruffstuff towers look to fit well with a 10 degree rearward and 10 degree inward tilt at ride height, C/O's mounted 3" behind axle centerline and outboard 2.75" from the coil mounts. This avoids the airbox/mc clearance issues.
I don’t know got to tell but I got them used almost exactly 1 year ago.
Might be a tag like this on the bottom of the spring. Possibly not though, mine is nearly falling off after a month.
This is the more legible one of the two
Same issue, curiosity stemming from what GW nugget said above. Hearsay as far as I know, but @GW Nugget might be able to elaborate.
Dobinson and slinky springs come out of the same factory as I recall reading somewhere in the labyrinth of slinky threads on mud. That could even be Darren's scapegoat if he wants to investigate.
I have had reports back & read in threads of the tapered Dobinsons having variance in lift more than speced when loaded normally 1" but worst report was a 2" rear tapered of 25" fender measurement loaded... :hmm: Dobinson also staits lift height is loaded.
Interesting. Again, thanks to Kevin for fixing my problem!
