I haven't updated my build thread yet because I've been so busy trying to get this thing together for our trip to the Tetons on the 24th. The short of it is that it's back together. Gears are breaking in great, motor is running beautifully, the new trans is smooth and firm, and I put a used transfer case in because I've got a bearing going down in the one that was in it, and I'm out of time. My problem is this thing is 2.5-3" higher than I thought it was going to be. Visually, and for what I'll use it for, it's higher than I'd like, but it's growing on me... My biggest problem is that I've got crazy strong front driveshaft vibes, enough that I'm worried about it tearing something up on a 5000 mile trip. It definitely causes major transfer case noise on deceleration. I've got 26" hub to flare (and 6" difference between the panhard mounts), and maybe I made a mistake, but I was thinking a 3" lift would put me around 23-24". Either way I need to figure out the right way to tackle this quickly. It's got 2.5" LandTank caster plates on it now. Do I pull those off and swap for the 4"? I don't have caster measurements, or driveline angles, but I'll get them tomorrow. Right now it looks like a DC shaft would be perfect, but it doesn't have enough caster to be comfortable letting anybody else drive it. If I fix the caster with plates or arms, will it put me back into a place where the standard driveshaft should work? I'm thinking I'm into 5-6" territory, and all the research I did was around 3"... Somebody point me in the right direction, because I've read so much at this point that I don't know what works anymore... (and does this really look like a 3" lift on 35s???)
