Hey guys,
So I was having a pretty bad squeal coming from the brakes and when I took a look one of the calipers was frozen. Plus there was a good amount of rust down there and everything is 20 years old, so I decided to replace everything. Perhaps this was the first mistake. That being said, I put on NAPA reman calipers front/rear, poterfield pads with the T100 version up front, stainless lines front/rear from Slee, new disks front/rear, and some good high-temp Motul fluid. And for what it's worth, I've been running the 17in FJ Cruiser steel wheels with 35in Cooper Discovery Maxx tires since last fall.
I did the initial bleed and drove it around and it's definitely squishy. I don't subscribe to that break-in slam-on-the-pedal-and-glaze-the-pads theory, so I drove it normal for the first 100 miles or so. Bled it again after a few weeks of driving it and it feels the same. I've bled it with the engine on and vacuum booster running (the first time) and with the engine off the second time. Flushed out the lines both times with many pumps at each station. When pumping without the vacuum boost, the pedal gets rock solid with very little throw. With the booster going there's several inches of pedal depression before anything significant happens.
Before the second bleed, I was driving 30ish mph and went down a hill and the brakes heated up extremely quickly. I had only gone a couple hundred yards down this hill and I wasn't doing anything abnormal.
The order of bleeding was RR, LR, proportioning valve, FR, and FL.
Any thoughts on what else I could do to resolve this? I understand that I'm turning bigger/heavier tires, but I feel it's significantly underperforming despite this.
Thanks!!
Thanks!!
has Bled Brakes so many times (I drive old junk) that I no longer have to tell her "pump" and "Hold", she just does it. I just close my eyes....Ok.... I made that part up. Sorry I will get pics next time.
