Zjohnsonua
For the future...low tire pressure (think 30 instead of 40psi) can cause a more significant tire radius change than tire wear. This problem is often overthought.
If you plan to have the BP-51s rebuilt when they need it, having the stock suspension to swap back in could be beneficial. Otherwise they're a nice upgrade for someone with a high mileage worn out suspension. Lots of them have been given away, and some sold.Here is my SQOD - I am getting BP51s put on today. Is there any value in keeping or selling the old suspension parts? It's a 21 LC with 7,000 miles.
Thanks!
is there a specific thread for used/take off suspensions for sale or give a ways located in the classifieds?If you plan to have the BP-51s rebuilt when they need it, having the stock suspension to swap back in could be beneficial. Otherwise they're a nice upgrade for someone with a high mileage worn out suspension. Lots of them have been given away, and some sold.
Not a specific thread but this would workis there a specific thread for used/take off suspensions for sale or give a ways located in the classifieds?
I reinstalled the stock oil filter housing with 25 ft. lbs. of torque like it says on the embossment,
It's also really easy to get the housing o-ring in the wrong notch, which would cause a leak.Gotta New SQOD (Oil Change Related):
I changed my own oil last weekend and used a TRD Pro filter and O-ring, plus installed a Fumoto valve to make draining easier for next time. I reinstalled the stock oil filter housing with 25 ft. lbs. of torque like it says on the embossment, but left the skid plate off so I could check on it. FWIW- I'm 99% sure I put the new O-ring in the correct position. The next day there were a couple drips of oil on my driveway, so I torqued it to 40ish ft. lbs., but two days later there's still a little oil coming out.
Is it a big deal? Nah- if I'd have reinstalled the bash plate right after changing I would never have noticed. Is it a bit irritating as someone who likes to meticulously maintain my truck during the week and then beat the crap out of it on the weekends? Yes- yes it is.
So- my question is how tight do you DIYers actually torque the housing?
Gracias!
Gracias!
I was thinking about that after I posted. I’m so used to doing both that I forgot that you can pull the filter housing without getting showered by 8 qts of oil.You can empty the oil filter housing without draining the entire pan. Maybe 1/2 qt in there…. Or less.
I used a set of +3" stainless brake lines from Crown Performance. My Tundra-swapped 200 still has 200 calipers, so I simply went with normal Cruiser fittings up front. The +3" should be good regardless of the amount of lift you have up front, and it's plenty for the OME 722s I have out back.What’s the consensus on longer brake lines after the Tundra front end swap? Is there a simple part number from an aftermarket supplier that people find a good fit?
TIA
www.crownperformance.com
I did put on some very basic mudflaps, but they are only secured to the body. I had the same thought (and may try to remove them just to be sure) but I can't see how they would make this much noise. If I hadn't just put the bumper on I would be looking at something in the suspension binding up or brake calipers loose or osmething, but the bumper comes nowhere near any suspension or brake components and none of that has been touched.I would pop off the plastics on both sides and remove the swingout, then take it for a ride. If the noise is gone, you know you're on the right track. If it's still there, then I can't suspect the bumper. Maybe the mudflaps?
I have the same bumper, no noises. But I don't have the swingout installed.
Looks like sound dampening materialMy "new to me" 2008 LC was missing the cover to the oil drain plug. I purchased part #51456-60070 along with the two fastening bolts and was wondering what the two interior holes are for on the raised circular areas. In some picks that I have seen, it looks like some sort of plastic grommet extends out of them, but I cannot figure it out.
