Anyone had trouble with the connectors that came with the Slee group 31 battery tray kit? I was having intermittent trouble starting (like really intermittent - once a year or so), but the battery tested fine. Not high priority, so took me forever to finally check it out. I decided to swap out the positive connector to see if that helped, and was surprised to see this corrosion(?) on the side that meets the extender. New one (via Amazon) on the right:
Posting here because odds are I was the stupid one and didn't tighten it or something. I tightened the #$!@ out of the new one and the one on negative terminal, hope that was the problem.
I've had this happen a couple times... chalked it up to the terminals either getting dirty, being overtightened, or under-tightened.
Now I'm imagining a separate heat exchanger off the radiator, with a separate closed loop of water, running to a coil in the circulator pot. With an adjustable thermostat, depending on what's in the bath.
