You are correct. Sorry.I believe the pic from @CharlieS is a single compressor. If you have a twin then it's pressure switch under the shroud. Just checked mine and I don't have a visible pressure switch.View attachment 2180523
Maybe this one?Could have sworn there was a thread with NOT rock warrior wheel choices with pictures (and not the wheel & tire database, though, that is helpful, I need photos, small brain) - but I can't find it - and I don't want to create a new thread until I full due diligence - am I simply search challenged?
YES That's it dang it was searching for "RW" or "Rock Warrior" in the title, d'oh!!!Maybe this one?
Does anyone know the part number for the last section of the trailer wiring? (The 7pin connector and where it plugs into the wiring harness? I found this and trying to figure out if this will work for a replacement. 7pin connector
Here is a picture of what I am trying to replace
Not sure what all you need - HTH.
Look for Toyota part number 82169-60080. I found a pic of it on Ebay being sold by Manhattan Beach Toyota.
Anyone know how to stop the map from coming up after about 30 seconds? Whenever I select audio or climate, the screen will swap to maps after about 30 seconds. I cannot for the life of me figure out how to stop this.
Yes there is an option in the settings menu on your center screen to stop the auto switch. IIRC it is in the info tab
Hmm, the info tab only has the XM and app stuff, or so I'm seeing. Grrr...not sure how I'm missing this setting.
For the 2017 and the '20 models I've owned it's the Setup button, then General on the touch screen, then you scroll down until you see "Auto Screen Change" to turn it on or off.
It’s been done. Most recently @benc and @Eric Sarjeant did oneDoes anyone make an ARB compressor mount for the front passenger side of the engine bay by the power steering reservoir? There is a big open area that seems like the perfect spot since I don’t need a second battery.
forum.ih8mud.com
