I actually like it without the cans. Wife already giving me crap for taking them off.Bumper looks good without the cans on the front. Are you thinking of leaving them off?
Wonder what would be a good color for the bumpers besides green?![]()
JimToyota Ash Grey Metallic is the factory color for bumpers, grille and front fender vents. Paint code is obscured on the pint I have but others on here can provide.
I’ll see Mike soon and make certain he calls you.
When I did mine, I ordered the later model disc brake MC that came with the “kit” from cruiser outfitters. Is has dual reservoirs for front and back. Easy swap.Question, with the front axle swap for the disc brake conversion coming up what is best master cylinder for this? I assume this will have to be swapped? I do have access to new 55 which is what I was planning on, any holes in this plan? Figure I would also snag some brake lines for it?
I had gathered these things up for the green Pig that now sits at @Pigeaten's place. Early non-ABS FJ80 1993-94 master cylinder. I got mine from Kurt. @65swb45 makes a conversion plate for the fire wall to go from 3 bolts to 4. That is supposed to work fine with the rear drums. There isn't enough room for a booster to easily fit, but supposed to be plenty of braking force running the MC manually.I am trying to nail down what 80 series MC will work for us when swapping a disc front axle onto a Pig.
My brake lines come in from the side, so there is that.
I think for disc brakes you want a smaller bore MC to deliver more pressure
I think we also want non-ABS 80 MC.
If you have rear disks, there is the option of Wilwood MC4 calipers with a fj60 handbrake - only tested in the garage so far, but seems super solidThe only other E-brake option with the split case
Should have seen my expression!!!!!She looks concerned![]()
She drives our Troopy all the time, intimidated by the column shift.If she’s not used to stick shift put it in low range. Makes starting out easier. Worked with our kids.
