Silicone on windshield frame hinge screws
Oregon
Is there any theories out there as to why Toyota puts silicone on the windshield frame hinge screws? My guess is to keep moisture from blowing into the windshield frame when driving, thus preventing rust long term.
I'm about ready to install my windshield frame so trying to formulate that plan.
I think POs put silicone on the windshield hinge screws. Toyota just painted them assembled.
I'm pretty sure they came from Toyota that way. I have several windshield frames that I've taken off that had the same silicone on them. All windshield frames have been 75 or later.
Well, I bought my 78 new and the windshield hinge hardware had no silicone on it. Still doesn't.
It's standard practice when engine building to put silicone sealant on the threads of any bolt that enters a water jacket for example. Maybe Toyota expanded this practice for water intrusion points for a brief period of time.
Just to clarify, are we talking silicone on the threads or over the head of the screws?
I've seen the silicone on the threads only. Some bolts have excess silicone that can be seen globed on at the end of the bolt threads.
The head of the bolts are always clean with paint on them, no silicone.
Silicone and steel do not mix. Seam sealer would be fine, might make it hard to take apart in the future if you need to.
Here's a photo to describe what I'm talking about. Looks and feels an awful lot like silicone. These are taken from a November 1979 built.
I must say I have little knowledge on 79 + original vehicles. When I redid my screen, I used anti seize for longevity. If Mr. T did use silicon 79+, it is because the frame was NOT countersunk and would bleed over the threads. After 1976 Mr. T was cheapening in a lot of areas, yet , improving on driveline.
I have seen those globs on something on my FJ40 - perhaps WS bolts. I slather them with anti-seize (like every bolt except head bolts) upon reassembly.
Yes, I went the anti-seize route. Just makes me wonder why they put silicone on in '79?
Again, no countersink in mfg. Saves money. Now , if they did which I doubt, it was because the cheap, recycled steel on these vehicle , it would delay rust from bleed thru threads.
