Build rocks and rolls
updates damnit!
updates damnit!
Any updates
Any updates
Dont get onto mud very often..
This last summer I cut the rig up.
there is only about 3 feet of frame left and the rest is tube.
Kept the hood and the firewall
Yep that was me... I head out to the hammers every other weekend...
I thought I saw this on a trailer last saturday heading east on the 91freeway. Looked good!!
Kept the hood and the firewal.
I knew that gonna end like it did .. looks sweet !
thought you change ( lower ) yoour coils spring rate ..
I like it, still kinda looks like the "full" bodied version.
I mounted the the engine and drive train as high into the body as possible and as a result I had to fabricate a new radiator mounting straps that lift the raditor 3inches in order to center the raditor to the fan.
Used two pieces of channel mounted to a stud that attaches to the stock placement of the cross member.
I ran two verticall rods which attache to another piece of channel on the top of the radiator. The vertical rods then tighten with nuts.
Fabricated a fan shroud that attaches to the bottom pieces of channel and to the top of the channel.
The radiator then attches to the firewall with two addjustable heim joints (rods).
View attachment 210781View attachment 210784View attachment 210785
Probably no one reading this thread now, but in the unlikely event someone is watching: why did you decide to mount engine as high as possible? You raised your CG. Needed room below?
