Maybe it's time to replace the points, cap, rotor, etc. ? Distributors wear out and can misfire. It sure seems like you've replaced everything in the fuel department.
Deep breathing while humming Kumbaya!Still cutting out. IDEAS??? Coil????
Just put plugs in, didnt have wires or cap! I am gonna put Rotor in today and order coil and cap and whatever else. Thing idles smoothly,good vac, just seems to want to cut in 3rd at higher rpms. So i stomp on it to keep it going.Maybe it's time to replace the points, cap, rotor, etc. ? Distributors wear out and can misfire. It sure seems like you've replaced everything in the fuel department.
Used a dime on Bonnie’s Karmann Ghia one night.I’ve alway heard you could set the points by using the edge of a book of matches, but I could never get that to work. Had way better results with a dwell meter.
That was the old trick on VW points, yupYeah, I've used a match book cover before, must be something out of the 50s.
FOR A BULLETT![]()
A throwback to when every car used to need 15 ash-trays.Cant recall the last time I saw a book of matches![]()
What?Not gonna pull tank Vinegar![]()
