We bought an FJ62/60 from a forum member in June of 2016. Didn't feel it was appropriate to start a build thread until now because we haven't really done much until the last few weeks. Really happy with the chassis on the truck and with the beginnings of the front end swap. Truck was mostly un-touched and very rust-free. It's a roll-up window, early year, FJ62 in "Red" with about 200k on the 3FE and stock drivetrain. Somewhere along the way the truck hit a chain link fence and the previous owner bought it all banged up in the front. The sheetmetal was replace with 60 parts and this is how we bought it (sadly the truck hasn't changed much in the last 8 months)
Sadly, the water pump seized on our way home and an amazing friend came and rescued us. I tried to do the pump in a hotel parking lot, but I think we all know how that turned out.
Once home though, it was a one day job. Did all the hoses and what not at the same time, factory coolant, distilled water.
So we drove the truck around for a while this way, doing odds and ends and trying to make sure it was reliable.
At this point we discovered a few things. The radiator leaked quite a bit, which was probably due to the coolant overhaul I did during the water pump replacement. All the flushing probably nocked out some corrosion or stop leak that was in there. We also had a p/s line fail and the oilpan was pretty drippy as well. So we got started on doing some maintenance things.
My partner in crime.
Then we drove it around some more venturing further and further just to get confident in the mechanics of the truck. We really enjoyed the way it drove and how it ran.
Started installing some creature comforts, like a Jensen 2din stereo with nav and a back-up camera.
The plan was always to get the truck painted so I knew this work on the back camera would be undone to some extent.
Then the fun started. Wheels! SSR Auswuch in 16x8 ET-1
Still looking for a loose fifth if any finds one lurking in a corner somewhere.
Did some LED headlights which are fairly nice. Wiring wasn't fun since the 62 harness was there and wasn't really all that easy to decipher. I got it all figured out after some wiring diagram work.
So this brings us to yesterday. We really started disassembling the truck for paint. I'm still going to fill the lower rocker trim holes and some other things, but we started stripping her down to get some fresh freeborn red done.
Always need to stay organized.
I'll try to keep this as updated as I can in the next few days as we get all done to go to paint. Then it will go dark for a bit as the truck will be with the painter for about a month. Then we get to start hanging all the fun stuff.
