Project Wrong Way Saginaw Power Steering Install
BenjaminCA
Oroville CA
Website
www.youtube.com
I should note, the FJ40 Saginaw power steering install is being done by the opposite of a professional. In every way possible. You may have some criticisms and feedback, please let them fly. Even if I don’t do it, someone else will find it helpful information. With that, here is part one…
I'm looking forward to watching this. I hope to do this to my crawler project, with the added challenge of shoehorning the steering shaft around the 1hz.
Oh that’s a rad swap. Not much room for steering stuff there?
If it looks like I'm making progress, don't worry I'm not. In this episode I manage to cut two holes, and lift up the power steering box and set it down again 69 times... give or take. Ran into some fitment issues, but we shall overcome. Enjoy the struggle, provide input if you got it. Like share and subscribe.
My 40 has a shackle reversal so I’m not sure how much different the front of my frame looks compared to yours, but attaching some pics of my Saginaw setup anyway. Might be nice to see multiple setups to help figure out what you need. Saw in the vid that you wanted it set lower so that the bottom bolts didn’t mess with the spring hanger and mine is mounted low like that. I am also a bit further forward as well. The hoses aren’t all nestled into the frame crossmember.
Lower Bolts
Upper Bolts
Mounting location a bit further forward on the frame rail.
Hey Ben
Look at how this guy did it:
You can see his cutouts in the first post. That guy seems to be a master. Like the one you are becoming. Hope this helps out.
Cheers from Switzerland, keep it up. Enjoying the show. Brought my wife a bit more into the whole Land cruiser world.
Your plasma cutting needs more practice but your welds look so much better then mine. When I installed my FJ105 steering box I also drilled and installed DOM tubing with ~1/2" ID with plate on both sides of the frame box. I did the same for the F250 shock towers.
Hey Ben
This is 4x4Labs Saginaw kit. Check their pics on this link. That’s the bottom of the frame.
Appreciate the help gangsters. I sourced a mounting plate from Advanced Adapters to try and make the process a little easier on me. I still managed to struggle. Drilled some smaller holes, and sweat a lot for the cause. Happy pride month.
A set of transfer punches would help with locating where the holes in the frame. Maybe a mag base drill if it will fit makes the drilling a lot easer. When I drilled my frame for the steering box and the shock towers my drill was to heavy in the horizontal and had to assist the magnet with a c clamp. When I did the tire carrier I had to drill all 8 holes by hand because my mag base would not work.
Yeah man. Pushing on it with my chin and trying to get eye level did not go easy 😆
I feel your pain. I just drilled a bunch of 1/4" holes in both aprons to attach the sheet metal for the Metal Tech fender kit. I used the tires as a surface to press against and stabilize the drill.
Try it with progressive lenses and rotate your head just enough the each eye is looking through a different area of the lens. Sometimes I just have to take them off.
Thank you bro, we shoot for a comedy. At least I do, and she tries to stop me.
When mine gives me that look, I pleasantly remind her that she chose me out of every human on the planet….
Looks great, can’t wait to see the test run.
