CLCC Trivia -- whose engine does this belong to?
Someone with a smoker in their cooking arsenal!
is it @Jakes40 ?
Nice job Liam!Did the rear springs/bumpstops plus AHC fluid and globes with @kouki on Saturday.
Truck made it to 305k miles with no AHC maintenance records, I’m realizing now that it was super bumpy for all the time I’ve had it… drives so much better now, and I still haven’t calibrated it or replaced the bushings yet.
This looks dope.For those that ever plan a Windrock trip; I highly recommend considering a combo trip and get a lake house on Norris Lake. It’s about 45 mins from the main Windrock store (main entrance), but there are numerous entrances to the park within 20 mins of Norris. I can give you locations for those entrances, or they’re very easy to find with a little bit of research.
It doesn’t get much better than a long day of wheeling and then jumping right in the lake. The Windrock bath house can also be atrocious when there is a major event going on like ATR or GSMTR. Their open field camping is nothing special (The Cove is much better IMO). We had a luxury house for less than $100 per person, per night. Renting a pontoon and cruising the lake was icing on the cake.
I miss my conversations on 2M with other hams. The nets in the Shenandoah valley are nowhere near as active as Warrenton. My days for the last week have been nothing but working on hay harvesting.No modification 2m/70cm Radio install in a 2.5 gen Tundra.
"Compactenna" is a compromise, I have not tested SWR yet. Mounted a on a Rago Ditch light bracket milled out for the NMO mount. Routed the coax through the cabin air intake/windshield washer plenum and back out with the wiring harness. View attachment 3721842
Ribbon cable for control head fit perfectly in the console trim panel front joint and routed back through the console to the floor carpet seam by the console box. I have not decided what to do with the handmic yet. It attaches to the the main body of the radio and not the faceplate.
Main unit fit nicely on an aftermarket bracket made for fire extinguishers.
Chris...hands down.
What gave it away? The pellet grill box?Chris...hands down.
Speedy sleeve will cover that.Went to replace a leaking rear differential drive pinion seal; also found that the rear housing cover had started leaking from the bottom bolt. There was no gasket on the housing cover, only RTV.
I have not closed anything up yet while I:
1- wait on a housing cover gasket to come in
2- second guess what is below the pinion bearing. It should be a shim and washer and I can just torque away, but could be a crush sleeve since this has been apart. I am not confident setting preload.
The old oil seal was in rough shape and the rubber brittle. The old pinion nut is 30mm.
The flange surface where the seal will ride also gives some pause. It is not deep or sharp enough to catch a razor, but you can feel it.
View attachment 3733834View attachment 3733835
Nice. Just like the Slee's on my green 80.No bump out, just a 30% rake....
Hope to have mine installed by tomorrow before the meetup but we'll see. Those look great!Got a set of NLA (closed shop) Shrockworks sliders for the 4Runner on Marketplace for $500. These things are beefy, DOM tubing that bolt to the frame using existing holes with captive nuts on tabs to fish through the frame. No bump out, just a 30% rake....exactly how I would order if I specified myself. PO's wife is short and complained about getting into his truck, so he reverted to some auto drop steps. Never been off road, nor will they most likely on mine either (work DD), but I love the protection that they offer and look awesome too.
It did
Waiting for a block of free time this coming weekend to get it back together.
