Awesome post above, @ToyotaMatt.
I did do it, but have not driven it yet due to life taking over this weekend.
- Thanks for the Toyota sealant part number. I used Permatex 85420 that I had on hand. It is not RTV, but a tacky product like you describe.
- Good to know on not using new stake nuts; I have been wasting money for a while it seems.
- A note on torque and matching the stake nut- the pinion nut was staked, but well below the torque it should have been when I took it apart. I hit the same location on the nut at 30 ft lbs putting it back together. It went to the second blue line below at 60 ft lbs and did not move again coming up to 144 ft lbs per the FSM.
Note- pinion nut not restaked when this image was taken.
Side note- Water temp sender wire standoff bracket is supposed to go on intake manifold or valve cover?
Second side note- must be heat from the headers cooking anything plastic or rubber close to the motor on this side. All the hoses were cracking and the water temp sender connector is disintegrating.
Got the 10% under drive in plus the part time spool and Tom Woods DC rear drive shaft. Drives great and a bit more pep from bottom to top.
