The code clearing seemed to work for now to pass emissions/inspectionsLet me know if you need any parts for it, I might know where some are....just sayin!
Guy here on MUD makes a EGR test plug kit that takes care of that issue. ~$40
Looks like a female crimp pin check Amazon compare sizes and they come on round or squareBeing the impatient person I am, I tried to fix the marker lights since Ironman directions are useless! I didn't have enough wire to cut and solder again so tried swapping the pins. Well I messed this one up and don't know what to Google to buy another one to crimp on the wire.View attachment 2607791
you should be able to get marker light wiring pigtails right from toyota, i just had to do it for the fog lights on my tundraBeing the impatient person I am, I tried to fix the marker lights since Ironman directions are useless! I didn't have enough wire to cut and solder again so tried swapping the pins. Well I messed this one up and don't know what to Google to buy another one to crimp on the wire.
I hope they didn’t mean the fill plug!The dealer said they couldn’t do my trans service because the drain bolt on the pan got really tights and they where trying to take it out. I got it home and took almost no effort at all and it spun right out smh
no they never even got that far. It was definitely the drain, it did have a "tighter" spot when loosing it but nothing the tech shouldn't have been able to do if he had just put his purse down for a second. I'm going crack the 24mm fill plug just to make sure it opensI hope they didn’t mean the fill plug!
What year landcruiser?Being the impatient person I am, I tried to fix the marker lights since Ironman directions are useless! I didn't have enough wire to cut and solder again so tried swapping the pins. Well I messed this one up and don't know what to Google to buy another one to crimp on the wire.View attachment 2607791
I am in the middle of searching out pins to rebuild a harness that I wrapped around drive shift for front actuators on e locker for 94What year landcruiser?
@Malleus Do you still have pin info handy?I am in the middle of searching out pins to rebuild a harness that I wrapped around drive shift for front actuators on e locker for 94
That's from an IronMan harness so not factory.What year landcruiser?
More info please. Is that from the Ironman side or the Toyota side. Do the sides not mate, or is there an adapter for in-between the two?That's from an IronMan harness so not factory.
It goes into the IronMan marker lights. Their instructions were horrible on which wire goes to ground and which connects to the respective power for the lights. We cut the wires so there wasn't a bunch of slack. Well its wired backwards and since I didn't have enough wire near the lights to cut and resolder I tried repinning the Ironman connector at the marker lights. But broke one of the pins.More info please. Is that from the Ironman side or the Toyota side. Do the sides not mate, or is there an adapter for in-between the two?
Just in case anyone still needs it, yes I do. It's too large to attach here (it's 5MB). If anyone needs it, let me know and I'll send you a link.@Malleus Do you still have pin info handy?
Yeah, man. I need to see that new/old lathe. I'll hit you up before running some errands this week.@JohnVee, drop by sometime; I have beer in the fridge. And a new garage/workshop. Still more workshop than garage, but I'm working on that too.
I have found the plugs and the pins and the plugs, I just need to figure out correct wire colors and where they go into the plug (yes I am a bit anal@Malleus Do you still have pin info handy?
If anyone has a pic of the backside of the plug that plugs into the actuator that would be greatly appreciatedI have found the plugs and the pins and the plugs, I just need to figure out correct wire colors and where they go into the plug (yes I am a bit anal) I plan on building a factory harness
@roadstr6 installed locked axles from a donor truck recently. He may have the best available truck for pics.If anyone has a pic of the backside of the plug that plugs into the actuator that would be greatly appreciated
