So what's the tank out of?
What year Trooper ??
i do not know i did not look at year but i believe any newer style troper will work
, I think I may just buy the OEM filler neck, it has the valve and everything elseOnly reason i did not go with oem filler neck is the price but you will need to cut the filler pipe anywayThank you, I think I found a freebie tank, I think I may just buy the OEM filler neck, it has the valve and everything else
The OEM filler pipe is a freaking work of art!!!
reason i like my filler it is really simple there is nothing to go wrong easy to fill up and easy to make
I got my oem dual filler from @Akella . It is the diesel style with the large flapper for the larger spout. It was a lot of money but I love it. I am getting close to 400 miles before the light comes on, at least highway driving. Around town would be the same if I could keep my foot off the fun pedal! When my gauge reads 1/4 tank I hit my transfer switch and it runs right back up to full.Thank you, I think I found a freebie tank, I think I may just buy the OEM filler neck, it has the valve and everything else
Needs better protection - I have bent the flapper shaft twice now. When the shaft bends the pull lever will not operate.
Mine is still going great after 14 years.Only reason i did not go with oem filer neck is the price but any way you will need to cut the filer pipe anyway
The OEM Dual filler is easy to operate.. Im not sure why Phil has bent the rod on it. I have two in use and haven't had these issues. One of them is on the lx450 chinook and is exposed. Alkella can order the extra rods and pull knobs if you can find one with missing parts.
