Overheating problem
I've got a '94 that is overheating and I cannot figure it out. It has 230k on it and I have had it for four years. I replaced all the fluids and all the hoses in it when I got it and it has been relatively trouble free up until lately.
Here is the history... back in December I did the temperature gauge mod. A few weeks ago, while climbing a grade, I noticed the gauge creeping up but not hitting the red. I thought maybe the thermostat was partially stuck, so I replaced it. After pulling it, I tested it along with the new one, and they both opened at the same time. Drove it. Still did it. Then I figured it would be worth putting a water pump in, as I don't know how old the one in there was. While the pump was off, I had the radiator checked by a reputable local shop. It was given a clean bill of health and he suggested the head gasket. Then I thought, maybe it's a false reading from the temp gauge mod, so I installed an analog gauge when I put the radiator and water pump in. Same problem, and both gauges are in sync.
As my options were running out, I tried adding oil to the fan clutch (which is less than a year old) and a new radiator cap. Same problem. The fan is pulling perfectly, I can't stop it from spinning with a rolled up magazine at idle. The fan shroud is intact.
The last thing I tried was taking it to an exhaust shop and having the catalytic converters checked. Neither one was plugged.
On the way home from the shop, it got hot at the top of the grade (about 1,000' elevation change in 7 miles), so I put on the heater and noticed the temp went down shortly there after.
There is no water in my oil and no oil in my water. I did a block test on it twice to check for exhaust in the coolant. Nothing.
I am at a loss.
Any thoughts?
Check your fan belt tightness and condition.
Also, you are REQUIRED to read the ultimate overheating thread by @NLXTACY . (It's only like 300 pages)....He'll post the ink.
Check your idler pulleys as well.
Do you have anything blocking your radiator (lights, bumper, winch) or is it full of mud from an outing? Maybe rinse out the radiator from the inside of the engine compartment out. Don't use a pressure washer, just a garden hose and you can use a spray nozzle, just don't bend the fins.
Make sure the cooling system has been properly burped to remove all air pockets.
What about coolant mixture? Mostly distilled water or mostly antifreeze? I believe mostly water is best for cooling.
Idler pulley replaced 2 years ago. Belts are fine. Front end is completely stock and there is nothing blocking air flow in the ac condenser. I thought about the burp, but I'm pretty sure there is no air in the system and I was doubtful it would be the same issue three times in a row.
At this point, I'm leaning toward throwing a radiator at it, in spite of what the shop said about it, and seeing what happens.
I just replaced my rad with a quality Alloy version and getting my original copper one fixed up if possible. Problem i have where i live was i have to send it away and couldn't wait that long so ordered a new one (no copper ones available at short notice). Anywho long story short my truck was overheating and i couldnt explain it. no coolant loss, belts and hoses were fine but when putting the AC on during hot days it overheated too quickly.
Once my oil cooler housing decided to pop the problem became evident. There were coolants that had clearly been mixed and this caused small blockages in areas where coolant circulates and subsequent overheating but not enough to drain the coolant down like a gasket leak. Once the gasket and oil cooler cover started leaking obviously the coolant was at a loss and i had no choice to start pulling the truck apart.
My advice, if your rad is getting tired just get a new one anyway they are cheap and you can get good Toyo versions at good price , flush the system completely twice with distilled water + flush treatment, contrary to some advice i would also replace the belts if not new and replace the water pump gasket and check the bearing on the water pump. Another thing is your fan clutch, check your fan to see how well its spinning. If its weak and easily stopped your fan clutch has had it. All these small things can add up to a bigger problem such as overheating. I was warned not to even touch the water pump but im glad i did as there was some oxidation on the pump and needed new metal gasket. The advantage to doing this is some OCD preventative maintenance while you hunt for the problem. Last thing you need is cooking your engine in the middle of nowhere.
Just think, the cooling system somewhere has to be responsible unless its a false reading which i doubt. The rad or head gasket will usually be the culprit outside of the little electronic readers etc. Even stop coolant leak if not flushed out after use can cause this in my exp.
Lastly if you are worried about carrying out this work yourself i wil be posting a vid up in the next day or so explaining how to do this but aimed at less experienced members. :)
Inspect your spark plugs and look for signs of a lean mixture or over advanced timing. Perhaps the engine is putting more heat into the system than is was designed to handle.
Koyo A1918 from Autoplicity is cheap ($176), and fast delivery......free shipping. I just got one.
Koyo A1918 Radiator
I took the last one last week. Should be back in stock soon....the price drops when in stock.
Do it. I had similar issues with a 3 year old brass Koyo. Posted pictures up here and no one could see any visual issues. Replaced with a 2 row aluminum, 170F thermostat and 7k cst in the fan clutch. I don't recall seeing over 194F coolant temps in 100+ weather since I did. Best of luck.
I haven't put a light on the timing as of yet. When I was into the distributor a few years back, I put hash marks on the housings and they are still aligned, so I am inclined to think it is still fine, but I will look into it.
I finally have an update. After checking out everything other than the hg, I decided to give it to my brother and have him pull the head. The head gasket was the blown. At least now I know...
Bad news. My brother did the top end on it and I am still having the overheating issue. Now that literally everything in the cooling system has been replaced, the cooling system flushed, the timing checked, the timing advance checked, I decided to teat into the exhaust. I tore it out from the cats back. One cat had disintegrated about halfway through, but there is no obstruction to the flow. The other cat looked fine as I could see through it, and the holes looked square and did not appear plugged. They both flowed fine when I blew air through. The remainder of the cat that died sounds like it ended up in my muffler. I ran a snake through all parts of the exhaust system, as well as blowing an air chuck through and am not noticing any obstructions. Anybody have any thoughts?
I think your radiator is bad. I know you said you had it tested but I don't trust the results.
I had the original tested. Then I replaced it anyway with a brand new one. Same result. I've also gone through three thermostats, all checked before install and worked properly, two water pumps, new fan clutch that I cannot stop when the engine is warm at an idle, new radiator cap, hoses are not collapsing, etc.
