Sounds like you might benefit from a more efficient radiator (despite the diagnosis of the shop that looked at it).
I'd be inclined to play with the ignition timing as well. IF your vehicle is on the verge of 'pinging' (under load) then the knock sensors will pick that up and the ECU adjust for it....BUT the engine is still straining and will build heat.
There are so many little things...that cumulatively effect the cooling system. You have already addressed some of them.
Things you can do (or check):
*Replace radiator with a proven brand/design.*
Make sure your Radiator cap is functioning correctly.
Coolant mix percentage only needs to be sufficient for the coldest temps you expect to encounter.
Check fan clutch for proper operation.
Check belt tightness.
Check that your fan shroud is properly mounted and if your 'foam' is missing from around the radiator/shroud replace it.
Check timing, experiment with it...if needed.
Check your A/C condenser for obstructions, clean if needed. Air has to flow through it first to get to your radiator.
Check your radiator hoses for softness, replace if oil soaked and weak.
Check for excessive back pressure in exhaust system (particularly the CATS).
Check engine oil viscosity and examine for fuel smell. A stuck injector can cause fuel to enter the crankcase, diluting the oil.
Check that your ignition system (Plugs, wires and coil) are working correctly.
So, to recap, there were no issues until May of 2017 when the weather got hot. I do not pull a trailer.
The hoses and belts are fine- no collapsing and proper tension. Fan clutch was replaced in late 2016 with blue fan clutch and additional oil was added, not sure the spec, but the fan pulls hard.
Since the overheating problem started, here is the list of things done (not necessarily in order):
2 new thermostats- original and each new one boiled prior to install- they appeared to operate normally.
Ran it with no thermostat
Original 3 row Koyo radiator professionally rodded out
New 3 row Koyo radiator installed
new radiator cap
analog gauge added to insure factory gauge (with mod) was accurate.
cooling system flushed with a prestone flush- ran it for 3 days with the flush
new head gasket- head decked while off
exhaust pulled, cats removed to check for back pressure
timing checked
timing advance checked
tranny and a/c cooler and condenser checked for heat transfer
obstructions to air flow through the a/c condenser and tranny cooler checked
fan and shroud checked
oil cooler pulled and checked for build up
coolant is roughly 50/50, maybe a little under that
burped system countless times
Fan and shroud are fine. I never had any foam in the radiator/shroud to begin with, but there does not appear to be much if any gap.
I don't notice anything odd regarding oil smell/ fuel transfer.
It doesn't seem to matter the grade of fuel I run.
I think that covers it.
I'm still reading NLXTACY's thread to see if I have missed something, but it is hard to put aside the kind of time required to read that in full. It's like a novel.
