So, to recap, there were no issues until May of 2017 when the weather got hot. I do not pull a trailer.
The hoses and belts are fine- no collapsing and proper tension. Fan clutch was replaced in late 2016 with blue fan clutch and additional oil was added, not sure the spec, but the fan pulls hard.
Since the overheating problem started, here is the list of things done (not necessarily in order):
2 new thermostats- original and each new one boiled prior to install- they appeared to operate normally.
Ran it with no thermostat
Original 3 row Koyo radiator professionally rodded out
New 3 row Koyo radiator installed
new radiator cap
analog gauge added to insure factory gauge (with mod) was accurate.
cooling system flushed with a prestone flush- ran it for 3 days with the flush
new head gasket- head decked while off
exhaust pulled, cats removed to check for back pressure
timing checked
timing advance checked
tranny and a/c cooler and condenser checked for heat transfer
obstructions to air flow through the a/c condenser and tranny cooler checked
fan and shroud checked
oil cooler pulled and checked for build up
coolant is roughly 50/50, maybe a little under that
burped system countless times
Fan and shroud are fine. I never had any foam in the radiator/shroud to begin with, but there does not appear to be much if any gap.
I don't notice anything odd regarding oil smell/ fuel transfer.
It doesn't seem to matter the grade of fuel I run.
I think that covers it.
I'm still reading NLXTACY's thread to see if I have missed something, but it is hard to put aside the kind of time required to read that in full. It's like a novel.
