You really boogered that surface up. I would get some "right stuff" RTV and fill those holes and lay a thin layer on both surfaces.
Do you already have a regular impact driver?I've had my eye on the Milwaukee M12 right angle impact as I already have a few of the M12 tools
@IdahoDoug : is this what you use or ??
M12™ 1/4" Hex Right Angle Impact Driver Kit
www.milwaukeetool.com
Not true, unless that has changed in the last 3 months. I have wiha JIS + bits and various JIS screwdrivers. People can say what they want, but using the right bit makes a huge difference. Same thing with the funky british bits on the land rover. So many cammed out and destroyed fasteners until we got the proper bits.I don't think you can even get JIS anymore- it was sunsetted back in like 2006. Even the vessel stuff you order from japan isn't "true" JIS and it's whatever new standard they use.
From what I've looked into, the JIS standard for screwdrivers expired in 2008 and they're all DIN 5260-PH/ISO 8763-1 standard now.Not true, unless that has changed in the last 3 months. I have wiha JIS + bits and various JIS screwdrivers. People can say what they want, but using the right bit makes a huge difference. Same thing with the funky british bits on the land rover. So many cammed out and destroyed fasteners until we got the proper bits.
I first felt the pain on japanese motorcycles in the 70's and 80's. We quickly learned that a philips bit is a great way to strip the heads on the screws holding carburetors together.
This is like rain man levels of semantics.
I agree with you, i think the OP should follow this advice in spadesMaybe in the future, you should consider paying someone else to do the work.
I bought one specifically for this job back in 2018. I should have got the JIS bit but didn't know about it at the time. Still worked great.I don’t know why people just don’t buy a Philips impact screw driver.
I used the exact same tool.
A impact screw gun does the same job.
And brings you into 21 century.
I’m not sure what happened to it but I use to have one of those screw impacts drivers when I was a kid in the 70s
I used it to split the cases on motorcycle engines,Yamahas
back then no one I knew was familiar JIS bits.
We did know that they stripped very easily.
I used a small Makita impact screw gun to remove the screws on my oil pump cover it worked perfect got all the screws out without stripping any![]()
Me too. Still have the impact screw gun and didn't even know what JIS was.I bought one specifically for this job back in 2018. I should have got the JIS bit but didn't know about it at the time. Still worked great.
I started with this, but couldn't get enough hammer swing to get them loose, so I went to buy an impact screw gun from somewhere just before the stores closed so I could finish getting it apart that day, based on advice from Mud.
I got all mine out cleanly (Craftsman screw gun) and installed all new OEM screws. Didn't have to drill any because I used a hammer and tapped in the bit prior to each one being worked on. I did not use Loctite on the threads when reassembled because that would make it worse for next time.A impact screw gun does the same job.
Hahaha thank god I am not^^^^^
Yep.
View attachment 3672051View attachment 3672052View attachment 3672053View attachment 3672054
****Use the right tools, right techniques, and there will be no carnage****
And I just said a prayer hoping the OP is not a Dentist.![]()
