SOLD NOS FJ55 rear window gear, SoCal
Status
Not open for further replies.
65swb45
Elder Statesman
Supporting Vendor
Website
marksoffroad.net
Not much else to say. $150 shipped. Postal Money order only. No PMs please. Mark
bump.
bump.
Time warp bump.
Based on the gear shaft I’m going to say 75-80. A swine connesseure may correct me, but I thought if you had the matching shaft, then the gear could be used in either early or late pigs.
Bump.
Mark,
Interested but need a couple of other items. I need the cover gasket for a 2F air cleaner gasket. I have good top and bottom air filter gaskets but the top cover gasket was too dry rotted to save.
I also need one of the four vibration suppression things (see photos). There are two on the top mounting brackets and two on the bottom bracket. Somehow I have misplaced one.
Any advice on replacement rubber grommets for those would be appreciated as well.
Thanks
I probably have a grommet, but have to check in the box when I am at the shop tomorrow.
Can you please leave me a Voicemail at the shop to remind me? Thanks.
Will do. Thanks
SPF. Thanks Greg.
Mark,
Thanks
did you find this?
did you find this?
Depends on which part you are asking about. I found the metal part of the grommet from Mark. I then cut out all of the rubber grommets from the metal and replaced them with grommets I found on McMaster Carr (IIRC) and then made a top gasket out of material from McMaster Carr. I'll find the area in my thread and post it shortly.
Status
