newbe needs advice?!?!?!?!
Central valley (Cali)
:doh: help,advice needed! I have a clean mostly stock 66 fj40.I want to build a clean , mostly reliable wheeler.Keeping in mind I have a family,and a budget.It now has a str.6 cly.,3 speed combo, stock toy axels.Iwould like to do a spring over,run 33 in tires, upgrade the fuel delivery ,engine swap? And i must build a cage ,and disc brakes.I just dont know which or what i should do first?Any advise or knowledge would be very helpful! Thanxs JAmes
order i would go in,
first a second mortgage
2. engine swap
3. upgrade fuel blah blah
4. disc brakes
5. roll cage
6. lockers
7. spring over
8. 33 tires
did i miss anything on your list, if you dont want a second mortgage sell one of your kids, probably get a good price for them. :)
See having a 65 and a 74 on with a 2F the other a sbc I would do the following!
1. Get your hands on a set of birfield axels, should be fair priced. Not that the ball and claw aren't good but no options for lockers or disks with those.
2. Aussie Locker
3. Power Steering.
4. Roll Cage
5. Disk Brakes
6. If you're set on a SOA then do it now.
7. 35 Inch Tires but that's me..
8. engine swap, I hate doing things that aren't needed, I'd get ready for one find the motor and stuff but I'd have a VERY hard time pulling a working F motor. I'll also add I wouldn't do the swap unless you had a T350, SM420, SM465 trans to go in at the same time..
Whelll... pull up an ice block and lend an ear.
I'd start with the brakes man. I fought with the drums on my old cruiser for 5 years and hated it, it was downright scary at times, dangerous even :eek: And brakes are your #1 safety concern. IMO.
Then if you don't have a roll bar I'd do the cage next.
SOA and tires next, I got by with my F for a few years runnin SOA and 35's.
Then engine swap and all the other goodies.
Just me ;)
Budget, WE DON'T HAVE NO STINKING BUDGET ! LOL. I guess it all depends on how hardcore you plan on wheeling. It's a progression thing, imo(in my opinion) I would start with a lift, soa or sua. Soa is alot more time and $ than a sua lift. No driveline mods and such, again it depends on use. A 4" lift will get you running 33's. A strong 6 cyl will do great in most situations. Headers, rebuilt carb(Jim Chenowith) and upgraded ignition will do wonders on that F. Stopping is good, so discs up front to start. Then maybe a Metaltech cage, and then gearing $$, lockers $ and so on 'til the wife says stop buying cruzer crap! Don't save or add up reciepts, It just ruins the fun ! My .02 Good luck
You will get lot's of opinions, all on what people would do better the first time around, hell I would do things differently too. The problem is you have to know what you like. My advice is keep it stock, wheel with other cruiserheads, and get a feel for what you are getting into. Then you can dicide which way to go.
Cheers,
Deny.
Ps if I had to do it again, I would skip the 3 in lift springs and go strait to spring over. but that is just my opinion.
hudyhue said:
I have a clean mostly stock 66 fj40.I want to build a clean , mostly reliable wheelerAny advise or knowledge would be very helpful! Thanxs JAmes
I would find a different truck to make into a trail rig. the one you have sounds like a good example to do nice resto on. keep it mostly stock to small mods. and leave if for light trails and mostly around town. not alot of them mid-60's around anymore, even less in fair condition.
but that's just me.
I agree with Brian... sell it and buy a truck that's already built the right way. In the long run you'll likely save not only a ton of money, but the issues that come with all the mods that people have already suggested. Plus, you won't have to wait nearly as long to get on the trail!
Didn't see a power steering conversion on that list...
That, brakes, and gearing are needed before you worry about tires and a lift....unless YOU are the POSER.... :)
Good luck!
-Steve
Poser - great reply here.....I saw you updated, and was getting ready for:
Newbie question? Read the damn technical links - its not that damn difficult! Do your own flippin leg work and quit whining.
Just read through the techincal links, pick an order based on budget and just do it.
No mod for a cruiser is cheap - so just quit your whining and pony up.
Of course, I missed the rolling eyes and such...he he he....
Oh - poser, "I am just giving you s*** man".....
all in good fun -
ragman
What to do first? Fix what is broken or not working well!
It sounds like you should just start driving it. Do the brakes stop well? Is it running well, does it have ok power? Are there vibrations in the driveline? Are the steering components in good shape, does it drive straight down the road?
Find out what issues it has first. Then estimate what it will cost to fix. Then see if you should do an upgrade in this area instead (price it out, etc).
Things to consider:
Brakes: probably better to just get a whole front axle for disk brakes on this vintage. So I would try to set some cash aside for the day you find a good deal on one.
Tranny: since you are on the cheap, if you really want a wheeling rig I would look for a sm420.
Tires & suspension: Since you say 33’s I would look into finding some stock 60 or 40 series disk brake wheels cheap and mount some 33X10.50 15’s. These will fit nicely with a moderate spring lift.
If you are really into 4-wheeling and have some cash on hand think about a locker or a winch.
It looks like a rusted out good running donor truck could go a long way too.
from a sort of novice cruiser and a longer time mild wheeler (in my husband's Chevy full-size), safety is the first concern: brakes and cage! Whether front disk brakes mean different axles, you'll have to ask the experts.
functionality second: even before bigger tires, I would go for a rear locker, single most noticeable upgrade in wheeling capability (at least my feeling on the hubby's GMC Jimmy).
the order on the other upgrades is a matter of taste: I am retaining the manual steering on my cruiser (doesn't bother me that much, just as with luggage in an airplane, if you can't lift it into the overhead compartment, what business do you have carrying the stuff - translated: why driving an old cruiser if you cannot deal with the manual steering; I consider it my wrestling practice), but I am currently installing things like a second battery, a real nice seat, new seatbelts (safety!), good insulation. Already upgraded to fool-proof wiring, hand throttle, new tie rod ends, beefier tie rod, rebuilt steering box, front disk brakes.
But I completely agree with everyone who said: just go wheeling different terrain and find out which problems you encounter and whether they are due to driver (in-)experience or to equipment insufficiencies.
