6 slots in those so they are different as well, I am going to have a look around on the euro sites and see what I can come up with, but like most things like this unless you have an eye for the aesthetics like this (and I do not) then you are better of copying someone else
As far as I can tell, this is the order on which the template has been requested. I will pass it on to the next guy on the list if the guy on top decides to pass:
Since the GXP louvers appear to be a bit difficult to find, has anyone considers other OEM louvers? Perhaps the early Dodge Stealth hood louvers? Can anyone think of others?
Looks really nice Rob, great job and attention to detail Please post some photos of the entire truck so the 255's are visible, it seams like every 80 looks different on set of those. Thanks for sharing this.
Be careful on those red ones. If it's the ones I looked at, I inquired about the size, W x L, and it was not the same as the OP used. Might work OK, but not the same as the template. Seems like they were smaller IIRC. John I did find the right ones from another Ebay seller. I think he had several more sets. But they were mucho $$$$ John
Because of the relative "precision" required to properly locate the cut-out in the hood, the "paper template" alone is of [very] limited usefulness.
Looking at the original post, it can be seen that the paper template only serves to locate the holes through which the locator pins go (the "locator pins" that are part of the wood cut-out template). In other words, you really need both parts (paper & wood) to make this method work.
Again, there are probably other ways to locate the actual cut-out in the hood with the needed "precision", but I was unwilling to risk cutting my one-and-only hood in the wrong place... even if it were off by 1/4" it wouldn't be good... and, of course, one would want the vents to be in exactly the same place on each side.
