Build My new pair of 40s
sand blaster round 2
I was able to get all the other glass out of the top no problemo........ but the rear glass now needs to be replaced
What did you use to paint the knuckle housing and steering arms? They look nice.
ome springs
new springs and bushings
also adding a 4* shim for my 1.5" shakles
http://www.englandhouseplans.com/fj55/fj40.htm
edit: long shakles are no good w/ new springs (Bouncey)
planning on anti inversion shakles to allow for full susp flex w/o possibility of breaking a spring
getting things done
installed ome springs, 1.5" wheel adapters, greasable pins, ome bushings, sor headers, metal header gasket, 80 master, 4 runner booster, new tie rods and ends
edit: wait till you see how the header paint melted....... didn't last 5 minutes
Nothing less than inspiring. When it warms up a little up here I am starting a full teardown of a 72 currently with no motor, but you make me want to start it right now.
By the way, love the dog, I pick up my bulldog on Tuesday. Hopefully she will help as much as yours helps you!
HEY!!
This is a GREAT job you are doing! Very inspiring indeed. I do have another question about the paint you are using. Are you using and thinner/reducer to spray it or are you spraying it 100% paint? I ask because our church has purchased a school bus and we need to paint it....If this paint will work for your cruiser, why not a 56 passenger bus?!?! hehe. I have painted a few times, but I always used the automotive basecoat/clearcoat system....its expensive. Thanks for all the great pics.
nice job, i like this build up alot. the header looks real nice as well. Glad to see someone else suffering doing most of there work on there own lol. just make sure you check on those wheel spacers alot, they have been known to work loose on DD's, just looking out for your safety
loctite red on all the spacers.
I really like the looks of the vintage vector wheels. My set doesn't have the correct b/s so the adapters are needed. I plan on getting "correct wheels" in the future. (widened stockers) Lets hope my wheel doesn't fall off 1st
munday- my dog flo is 7
Jim Chetworth (fj40jim) rebuilt my carb. Jim also supplied me with a 73 oem linkage setup from carb to pedal. I bolted on the carb and the engine fired 1st try It purrs like a kitten. Thanks JIM!!!!!!!!
installed a carb spacer from a 69 fj40
this required longer carb studs also
