Build My new pair of 40s
steering
think I need new tie rod ends? ha
my tie rods were bent so those are being replaced too
Dude, Whats wrong with me? I have more time and a better garage and I can't keep up with all you'r getting done. Your cruiser looks so good and is really coming along quickly. I am going out to work on mine right now!
I am going to be doing the same thing next weekend, is the dog available to help?
Mel - Looking great!!!
Where'd you get the new flanges and how much? I wanted to pick up a spare set, but everywhere I've found them seems to be too pricey...
mel lowe said:
the 4 speed has larger drive shafts than my 71 equiped 3 speed
in order to make the larger shafts work,
I had to get new flanges for my 3rds
to complete the job I replaced the seals, slingers and stake nuts
nice work
Mel, Chasing down parts, restoring a cruiser, and 70 hrs a week; That was enough. But you have a dog, too! Nice. Keep up the good work,I'm looking forward to seeing this rig competed. :beer: John
Nice job any particular reason you stuck with the coarse splined birfs?
and what type of grease did you use?
89s- grease came from tpi4x4.com belray brand
If I could do it again....
I would have upgraded the front to mini truck discs, knuckles birfs and arms, instead of the jto set up. I purchased the jto kit before I joined mud.
It is all a learning curve man...
When I think about all the things that I have 'learned' since 1988 and continue to daily, I just smile, and hope that I can prevent just one person some day from paying for the same college credits that I already have.....
This is just one of the many awsome things about Brian's site.
:beer:
22.
I think a lot of people leave these out on a rebuild and they are a source for problems down the road. WOrn bushing cause the hi speed gear to woble (since it is the one most used) and it causes the dogs and collar #23 to wear prematurely.
unfortunatly you need a press to replace these. SOmething I didn't have in the shop and didn't do it. WIsh I had. They aren't expensive from toyota and are just as valuable as any of the bearings in a transfer case.
Good job on replacing 23 a lot of people miss this also.
And 19 is another one that ought to be replaced.
15 can be skipped as long as they don't fall apart upon dissasembly (usually a sign to replace) but if 19 (idler gear shaft) is even slightly worn I would also replace these.
Good job in replacing what you did. SOme peole just replace seals and maybe the ouput shaft bearing and call it a rebuild. A long way from a true rebuild.
BUt there is nothing in the world that can compare to a properly rebuilt transfer case.
